Didn't Know this about resistors
Post by Resistance is Futile on Sat Feb 21, 2009 4:57 am
If you find a resistor with an extra wide first band, it designates that its a wirewound resistor not a carbon, Found the info in Mallory Yaxleys 1937 book.
Number of posts : 976
Re: Didn't Know this about resistors
Post by tube radio on Sat Feb 21, 2009 10:11 am
I didn't know it either thanks. bounce bounce bounce bounce
tube radio
Number of posts : 171
Post by Terrible Terry on Sat Feb 21, 2009 4:42 pm
Well I'll be durned. In all my years of puttering around this stuff I never read that. I looked in my junk box of old resistors but I don't have one. I was gonna crack it open to verify. I'm sure I've seen them with irregular width bands though and just dismissed it as having no significance. Gee whiz, I feel so enlightened now! Very Happy
Terrible Terry
Number of posts : 10
Registration date : 2009-02-08
Post by FM Refugee on Sat Feb 21, 2009 11:12 pm
...and that has the case in more recent years, too. Even more modern (70s or so) wirewound resistors had the wide first band...
FM Refugee
Number of posts : 14
Registration date : 2008-08-30
Post by Timaaay! on Sun Feb 22, 2009 6:14 am
I never knew that either. Thanks for the heads-up.
Timaaay!
Number of posts : 142
Registration date : 2009-01-20
Post by exray on Sun Feb 22, 2009 10:03 am
Another resistor tip - those carbon comps that are black as a base color as opposed to brown are NON-INSULATED. Remember that when touching for heat or placing next to other components.
exray
Registration date : 2008-03-30
Post by Terrible Terry on Sun Feb 22, 2009 1:07 pm
? I have trouble making sense of that, exray. If you mean insulated heat-wise, what would be the point of that? Trying to contain heat within a resistor would surely just result in heat build up within the resistor. If you mean insulated electrically, how could you have an effective resistor when the outer package is conductive?
Maybe it has to do with the dielectric of the material, giving a higher breakdown voltage rating to some?
Terrible Terry
Post by butch on Sun Feb 22, 2009 1:18 pm
it would work fine if as bill said it isn't touching something else that is conductive.butch
butch
Number of posts : 27
Registration date : 2008-05-09
Post by Terrible Terry on Sun Feb 22, 2009 1:24 pm
Wouldn't the current just flow through the conductive covering instead of through the resistive element? Or does this mean that there is NO outer covering and that the body IS the resistive element? Could be, I suuppose.
Terrible Terry
Post by exray on Sun Feb 22, 2009 1:35 pm
I guess what you see on the outside is the actual carbon element, smooth molded with the normal color bands.
exray
Post by Guest on Sun Feb 22, 2009 4:43 pm
I learn something new every day on these antique radio message boards.
Post by Sinatra1982 on Tue Nov 15, 2016 1:12 am
How can you tell that it is an extra first band?
Sinatra1982
Number of posts : 60
Post by Conelrad on Tue Nov 15, 2016 1:59 am
Not extra, but extra wide...
DG
Conelrad
Number of posts : 94
