steinite 102a
steinite 102a
Post by philco fan on Sat Feb 21, 2009 12:11 am
o.k i'll put up a biggee.
the victim is a steinite 102a if i remember right-dual 350's for output. the power supply was forcefully removed by dropping it out of the cabinet thereby detaching the 14 odd wires from the main chassis. after days of research and much work i finally figured out the connections so i could reattach the pwr supply and low and behold the behemoth sprang to life! but not the phono,anyone know how to check one of these old phono heads?the motor runs fine and i can hear music at the needle but nothing out of the speaker.
phil
schematic here;
http://www.nostalgiaair.org/PagesByModel/524/M0040524.pdf
philco fan
philco fan
Number of posts: 28
Registration date: 2009-02-15
http://www.freewebs.com/philcofan
Re: steinite 102a
Post by philco fan on Sat Feb 21, 2009 12:14 am
hi ken,it's a '29 radio/phono so no cartridge.it's one of those that uses steel needles.
phil
philco fan
philco fan
Number of posts: 28
Re: steinite 102a
Post by philco fan on Sat Feb 21, 2009 5:20 pm
o.k. i checked coil resistance at the head,2.2k so i'm guessing that's in the ballpark. on the schematic i don't even see the phono input,i need someone else to peek at it.
the pickup wires go to a control panel that has a switch-radio/phono- and a volume control,where would the head wires connect? the ends of the volume control? with them hooked there i get quiet output of phono out of the speaker.
the volume control is marked 50m-probably k-and measures about 70k.
phil
philco fan
Number of posts: 28
Re: steinite 102a
Post by Bill Cahill on Sat Feb 21, 2009 8:28 pm
The problem with these old magnetic pick-ups is the rubber gaskets dry out, and, the needle chuck quits moving within the magnet's field.
There are reliable rebuilders out there that will do a quality job re building it to like new condition.
Start with talking to Gary at VM enthusiasts.
Number of posts: 859
http://billcahill.webs.com/
