Radiola 17 resistor values.
I need the values of the power divider resistor in the power suppy of the RCA Radiola 17.
These values are not published on any of the circuit Diagrams that I have seen.
I have seen these values published some where but cannot find them. They were possibly on ARF Which is down right now.
Can someone help please. The values for a Radiola 18 are different.
Thanks.
Thanks.
Re: Radiola 17 resistor values.
Is this it?
http://www.nostalgiaair.org/PagesByModel/378/M0040378.pdf
Don Cavey- Senior Member
- Number of posts: 115
Thanks Don: That's one circuit Dia. that I've never seen.
A little different than others that are published.
Thank you very much
Thank you very much
The diagram I have shows that to be a 'tapped resistance unit'. The values are: 1690; 205; 2140; 3750; 410. All in ohms. Hope this helps. This info came from the RCA Service Data Book, the 'red' book.
Gene
Gene
Well Switcher, you seem to have all bases covered now. I like the team work that our usual members seem to have here and at ARF. All good guys...
Thanks again guys. I had over 100 volts on the plate of the #27 tube, should only be 35 volts. One of the sections of the divider was open. Got what I need now.
Lots of help here.
Lots of help here.
Similar topics» Radiola 17 resistor values.
» Power Supply questions
» Schematic for pre-1983 T-40
» Resistor and Capacitor values?
» How to set values for a checkbox choice list field? (SPFieldMultiChoice)
