What is this tube ?
What is this tube ?
Post by philconerd on Fri Feb 20, 2009 5:16 pm
I have acquired a boxful of used tubes and I cannot identify what this tube is. It is a Sylvania 40A1, octal base. Anyone know what this one is? It is not listed in my RCA tube manual nor my tube tester chart.
G.
philconerd
Number of posts: 8
Registration date: 2009-02-03
Re: What is this tube ?
Post by geno on Fri Feb 20, 2009 5:24 pm
The 40A1 is a ballast/regulator tube.
Gene
geno
Senior Member
Senior Member
Number of posts: 55
Registration date: 2008-03-13
http://www.genekidd.com
Post by philconerd on Fri Feb 20, 2009 5:29 pm
Gene-
Thanks for the reply. None of my old radios use a ballast tube. So, I would probably sell this one if it is good. Anyone know how to test this ballast tube?
G.
philconerd
Number of posts: 8
Post by geno on Fri Feb 20, 2009 5:37 pm
For more info, that tube is used as a ballast tube in the cathode circuit of TV sweep tubes, such as the 6BQ6 tube. I don't know how to test it, as none of my testers have it listed.
Gene
geno
Senior Member
Senior Member
Number of posts: 55
Post by Don Cavey on Fri Feb 20, 2009 5:58 pm
What did the Motorola VT-71 set use? I have one of those sets and the ballast is missing...
Don Cavey
Senior Member
Senior Member
Number of posts: 115
Post by geno on Fri Feb 20, 2009 7:04 pm
Don, I don't have the Sams folder 55, but that is where the schematic is.
Gene
geno
Senior Member
Senior Member
Number of posts: 55
Post by easyrider8 on Sat Feb 21, 2009 3:20 am
Check for continuity on pins 2 and 7, if is has continuity it is good. Emerson used these tubes in their TV's. These sell for 5-10 dollars.
Dave
easyrider8
Number of posts: 32
Registration date: 2008-03-28
Post by philconerd on Sat Feb 21, 2009 12:41 pm
Thanks Dave-
Okay I checked continuity for pins 2 to 7 and I measure 135 ohms. If this is within spec, I should probably sell this one.
G.
philconerd
Number of posts: 8
