Stovebolt engines
Page 2 of 2 Previous  1, 2
Stovebolt engines - Page 2 Empty Re: Stovebolt engines
Post by jerryhawthorne on Thu Mar 26, 2015 10:54 pm
One of the highest ratings from R/T and other car magazines is the BMW straight 6 for smooth power and performance.  Maybe Henry was not correct? Ragwire, thanks, it is amazing when you run out of radios to work on what idiotic ideas one can come up with!
Number of posts : 703
Post by Wildcat445 on Thu Mar 26, 2015 11:02 pm
Good workmanship and innovation should be admired whenever you see it. Great job, Jerry. Very Happy
A straight 8 idles smoothly as well. You could idle a Buick or Packard straight 8 at about 250 rpm and stand a nickel on the valve cover. Henry had his faults. He was not always right.
Post by Guest on Thu Mar 26, 2015 11:55 pm
Ragwire wrote:
MEZLAW wrote:That was not one of Henry's better moves.  Henry didn't like the 6 cly. engine because the number of cylinders did not divide equally by the number of engine strokes.   Four strokes (in Henry's mind)  was OK with the 4 cyl. and the 8 cyl. engines.  It was just one of many decisions which caused Ford to loose the sales lead to Chevy.
Great info WC!  Very Happy
That is odd...no pun intended. There is nothing smoother idling that a straight six. I used to just stand there and listen to the slow tickover of my '50 DeSoto 235 cu in 6...Like silk. I drive a modern V6 now, and there are certainly some engineering advantages to the vee type as well, but nothing idles as smooth as six-in-a-row-makes-it-go.
jerryhawthorne wrote:One more time, seems to work for me?
http://madscientisthut.com/wordpress/category/joule-thief/
Jerry, you a a tinkerer's tinkerer. Hats off to ya!
It is odd! and that's why I put in parentheses in Henry's mind. It was only his belief, not the truth! Wink
