hickok 209a VTVM
hickok 209a VTVM
Post by CHUCKSUE on Thu Feb 05, 2015 3:40 pm
Has anyone worked on one of these? I would like to restore it.
CHUCKSUE
Number of posts : 26
Re: hickok 209a VTVM
Post by 75X11 on Thu Feb 05, 2015 6:45 pm
I'm not familiar with them, but here's a start for you...
http://bama.edebris.com/manuals/hickok/209a/
Post by willy3486 on Thu Feb 05, 2015 11:49 pm
I have never worked on one like that but I am getting onto restoring these old test pieces. I have had a lot of luck doing so. I have restored a few pieces like a scope and generator in the last few years.
hickok 209a
Post by CHUCKSUE on Fri Feb 06, 2015 4:54 pm
I opened her up last night. The VTVM had no paper caps. I did notice that there was a resistor changed. They had two resistors in parallel that were 10%. The result was the resistance was too high. I also found out that the batteries have to be positive ground. I set the two pots that control a 10volt and a 40 volt level according to the schematic. I then calibrated the unit using my fluke to set the control voltages. I would like to find some wire to re pair the test leads. Other than that it is working fine.
CHUCKSUE
