Connecting a Dynamic microphone to a PC
Connecting a Dynamic microphone to a PC Empty Connecting a Dynamic microphone to a PC
Post by tuberadiogeek on Tue Dec 23, 2014 6:01 am
I have an old, but very good quality Motorola microphone I bought years ago that is just collecting dust. It was at one time set up for a UHF or VHF (someone once said it was popular with police departments)radio, but I had a friend that worked on C.B's change it to work on a C.B by putting in a switch out of another desk mic. It is almost like a power mic, even though it isn't. I'm pretty sure it's a dynamic and around 135 ohms. I was thinking about connecting it to a mono 1/8" plug and using it like you would on a radio. I would imagine the computer has enough power to support the mic, but not certain. What do some of you guys think? I not only want to use it due to it collecting dust, but to remember my friend, as he passed away about a year-and-a-half ago. He would be happy that I found another use for it.
Connecting a Dynamic microphone to a PC Empty Re: Connecting a Dynamic microphone to a PC
Post by 75X11 on Tue Dec 23, 2014 2:58 pm
Maybe Motorola Man might be able to tell you if you were to put up the model number. Our silver book went missing a few years ago so I can't tell you.
Post by tuberadiogeek on Tue Dec 23, 2014 5:38 pm
It's a Motorola Motorola tu532a-1. I pulled a photo from the web, so you can see what it looks like. Connecting a Dynamic microphone to a PC Downlo10
Post by Wildcat445 on Tue Dec 23, 2014 5:57 pm
I'm not sure about connecting a mic directly to a PC, but I use one run thru my Pioneer SX-1050 first, then to the PC. Mine is an old RCA, but I can't remember the model number right off hand.
Post by tuberadiogeek on Tue Dec 23, 2014 6:17 pm
I'm guessing you put it through the receiver first because the receiver acts as an pre-amp, right? I've read that it might require a pre-amp to boost the signal, but almost every pre-amp i've looked at on ebay is way too expensive, except a little phono pre-amp, which I would imagine it would be large enough to boost a microphone signal. While researching this, I came across a webpage where a guy destroyed a D-104 and an inexpensive computer mic. What he done was put the cheap condenser mic element in place of the dynamic element of the D-104. I wanted to slap the guy silly.. those mics are getting harder to find and expensive.
Post by Wildcat445 on Tue Dec 23, 2014 6:48 pm
I use it for a pre-amp and also because I know the output is compatible with the computer. I would bet that you will need a pre-amp of some kind.
Post by tuberadiogeek on Tue Dec 23, 2014 7:10 pm
I imagine this would work. If I can get it at the S.B. I will buy it. What do you think? http://www.ebay.com/itm/Realistic-42-2101A-stereo-pre-amp-/291328347337?pt=Vintage_Electronics_R2&hash=item43d485ccc9
Post by Wildcat445 on Tue Dec 23, 2014 7:22 pm
My PC is connected to the receiver by a tape out jack. I assume that the output is "line level." I would think that if the pre-amp delivered a signal similar to that, you should be fine. I don't know enough about the sound card in a PC to advise you further.
Post by 75X11 on Tue Dec 23, 2014 7:24 pm
Out of curiosity, have you tried it with no preamplification?
Post by tuberadiogeek on Tue Dec 23, 2014 7:31 pm
Thanks for the info WC.. 75, I have not tried it yet. I have yet to get a mono 1/8" plug and a 5 pin din plug, as I have one in an old CB with a bad so-239 connector. I'm planning to keep the mic cord in tact.
Post by tuberadiogeek on Wed Dec 24, 2014 12:51 am
It seems my laptop only has a headphone and aux in plug. I got my mic wired up, I used a stereo plug, but wired the switched side of the mic to the wire that corresponds to the outer tip of the plug and the other wire of the mic to the bare wire, which is the shaft or "ground". Unless my machine can not support a mic through the aux in, it needs a pre amp. I'm going to try my mic on my mom's desktop, that has a mic plug.*** A quick test on her machine shows it's working, but when I push the key button, it disconnects instead of connects. Exactly the opposite of what I wanted.***
Last edited by tuberadiogeek on Wed Dec 24, 2014 12:59 am; edited 1 time in total (Reason for editing : added info.)
Post by 75X11 on Wed Dec 24, 2014 11:23 am
I would've thought a dynamic mike would have some output signal. It never hurts to see whether you can save the expense of an extra you might not need.
Post by terrydec on Sat Dec 27, 2014 11:53 pm
Most PC's have three 3.5mm jacks.  The green one is headphone, but it can be amplified.  The blue one is line in and the pink one is mic in.  It should work with any hi or low impedance dynamic or crystal mic.  If you only have the blue then you need a preamp.  Parts Express has a couple of mic amp boards.  One is the 320-204.  This is only a board, no power supply, no mic input.  Just a chip and a control. But think how much fun it'll be putting the whole thing together.
terrydec
terrydec
Number of posts : 1124
Post by tuberadiogeek on Sun Dec 28, 2014 6:08 pm
I have a 1 year old Gateway laptop and it only has the headphone and an auxiliary input. They are both black and not color coded like on a desktop. I'm guessing the auxiliary input is the same as a line in on a desk top. I know the mic works when plugged into a mic input, as I plugged it into my mom's desktop. It seemed a bit sensitive but worked. I totally forgot about Parts Express, as it's been awhile since I've bought stuff from them. I'll have to check them out and see what I can find. Thanks.
Post by terrydec on Sun Dec 28, 2014 7:15 pm
look very closely.  There might be a tiny symbol around the jacks.  My HP laptop has an engraved mic and headphone, also black.  If I weren't looking for them I'd probably miss them.
terrydec
terrydec
Post by terrydec on Sun Dec 28, 2014 7:18 pm
More-
Most modern computers have only mic and headphone jacks and no line in, for programs like Skype.
terrydec
terrydec
Post by terrydec on Sun Dec 28, 2014 7:24 pm
Hint-
(I'm doing something else too, that's why I'm thinking in spurts)
Anyway- be very careful putting the cable on the plug. The cable is very large and that plug is REALLY small. Personally, I'd replace the mic cable with something smaller.
P.S. That really is a cool mic.
terrydec
terrydec
Post by tuberadiogeek on Sun Dec 28, 2014 8:02 pm
It has a symbol by it that looks like a mic, but in my audio properties it shows it as an internal aux jack. I just put some good batteries in an old radio shack condenser mic that was designed for a computer, and plugged it in the aux port. It worked like it should. So, apparently the aux jack requires a mic that is powered. It looks like I will be getting that pre amp board from parts express sometime. I'm just curious if that would operate with 9 volts, rather than 10+ volts? As it would be easiest for me to use a 9 volt battery or a 9 volt power supply, as I have quite a few floating around.
Post by tuberadiogeek on Sun Dec 28, 2014 8:48 pm
I didn't see you other posts. My computer is odd and only has the line in(basically). It works for an amplified mic. I plan to leave the 5 pin din wire on the mic, as I already made a make shift adapter for it. When I get the pre amp from PE i'm going to order a proper mono connector for the mic and make it neater. I'm also going to order a 9 volt battery snap and a 2 AA holder, and just run it off of batteries, that way I don't have to plug it in. Also going to get a box, toggle switch and LED for it. Everything is just under 23.00, with shipping it will be just undef 30.00. It will be a fun little project.
I bought that mic for 10 or 15.00 at Fair Radio Sales probably 3 or 4 years ago.
Post by terrydec on Sun Dec 28, 2014 11:02 pm
Sounds like fun- Keep us posted.
FYI- There is another place where you can get neat fun projects.  Ramsey Electronics.  That's where I got my FM transmitter.
Here's a video of what I did with one of the amp chips.  It's hooked up to my computer and sounds great.
https://www.youtube.com/watch?v=LYxqFP-9pko
terrydec
terrydec
Post by tuberadiogeek on Mon Dec 29, 2014 2:09 am
It will be awhile, but i plan to do it. I'll have to check them out. If I get a transmitter, it would be an AM, but they are a bit too expensive for me. I watched your video a few weeks ago when you posted it on here. That actually looked a bit complex at first, but after looking at the pre amp board it looks like something I could do. I would love to build a decent amp for my computer but i'd want to get rid of all my computer speakers first.
Post by terrydec on Mon Dec 29, 2014 11:58 am
tuberadiogeek wrote:It will be awhile, but i plan to do it. I'll have to check them out. If I get a transmitter, it would be an AM, but they are a bit too expensive for me. I watched your video a few weeks ago when you posted it on here. That actually looked a bit complex at first, but after looking at the pre amp board it looks like something I could do. I would love to build a decent amp for my computer but i'd want to get rid of all my computer speakers first.
If you get an AM transmitter from Ramsey get the synthesized, NOT the tunable.  However if you're serious I think some of the other members would agree to get the Sstrand.  Remember that the Ramsey is a kit.  I think the Sstrand is too.  I don't know about you but I LOVE putting kits together.  I wish I could get a job assembling kits.  The most complex one I did was the Heathkit oscilloscope.
I really miss Heathkit.
terrydec
terrydec
Post by tuberadiogeek on Mon Dec 29, 2014 7:08 pm
I was looking at one on Ramsey for 35.00, I believe. I know SStrand and talking house are about the best transmitters to get, but I would never use one that often. I've never really put electronic kits together except in high school. We did AM/FM radios, but I think the kits were low quality. The boards were crappy too, the traces for solder points would get damaged easily if you made a solder mistake more than once. Once they were damaged you couldn't solder any more. I still have it, only the AM section worked. The FM section worked but the tuning coils got damaged.
Post by terrydec on Mon Dec 29, 2014 7:18 pm
DO NOT get the $35 transmitter.  Period.  You will be VERY disappointed.  Trust me.  Save up.
If you feel uncomfortable putting together any kit I would be more than glad to help.
terrydec
terrydec
Post by tuberadiogeek on Fri Jan 02, 2015 3:28 am
I'm not getting a transmitter anytime soon, when I'm ready I'll post here for advice. However it looks like i will be ordering the mic pre amp kit tomorrow. P.E sent me an email with a promo code to save 5.00 on my next order of 25.00 or more. Which will take care of most of the shipping cost. I do have a question regarding the LED I want to use as a indicator lamp. I used an LED calculator online and it said to use a 560 ohm to bring my voltage down to 2 volts and current to 20ma for 12 volts. I was thinking about running the LED at 15ma of current which calls for 680 ohm since i'm using batteries (1 9 volt and 2 AA) and don't want to put too much of a strain on the batteries. Would that still be bright enough? Then I was just thinking about operating it off of 18 volts(9 volt x 2) since it can use 10-30 volts. Which would call for an 820 ohm resistor. That would bring it to 17.5 ma of current.
