Another Homebrew Signal Tracer Project
Post by Ragwire on Mon Nov 10, 2014 4:54 pm
Here is the second homebrew signal tracer project I made. I tried to keep it retro in styling and electronically. It is 100% "hollow state" --there are nothing but tubes in the circuits right down to the 6AL5 small signal rectifier to drive the meter. The speaker is a 5 watt, 4" unit. Fidelity is good, as it must be to find sources of distortion or excessive hum in an amplifier or radio. There is an output for an external meter or scope if specific (relative) signal voltages are needed or if the audio waveform or RF modulation envelope (demodulated) is to be observed visually. I also put in a noise test circuit with a momentary push button that puts out B+, through a high value resistor, to the audio input probe. Any roughness in this current flow caused by a cold solder joint or suspected "noisy" component is amplified by the audio amplifier. That test works similar to the old Eico 147 signal tracers.
I prefer a meter to an eye tube, so this meter was salvaged from the junk box. It is an old HP 400 series meter. The RF input probe uses a subminiature 5603WB triode as a grid leak detector to demodulate AM radio signals and amplify the corresponding audio signal, which is then sent to the audio-taper gain control potentiometer in the grid circuit of the 1st 12AX7 dual triode amplifier. The other half of this tube gives another stage of gain and feeds the grid of a 50C5 power pentode to drive the speaker though an audio output transformer. The secondary of the audio output transformer also feeds a signal to a 6AL5 dual diode tube to rectify the signal to the meter. The meter gives a relative signal level, and is responsive enough to bounce along with audio of a radio station or give a steady reading from a tone injected into the device being tested. The speaker can be muted by a single pole double throw switch that cuts out the speaker and replaces it with a 5 watt, 10 ohm load resistor. The power supply is a 35W4 half wave rectifier tube filtered by an RC pi filter.
The unit is sensitive enough to give a clear signal right from the antenna lug on an AM radio that is tuned into any reasonably local radio station, or can be turned down enough to get a signal right off the plate of a typical radio's output tube. It should be handy for audio amplifiers and phonos as well as radio work.
The faceplate and chassis are made from 6061 sheet aluminum. The cabinet is 1/4" red oak with poplar framework. The probe housing is made from 3/4" brass tubing, insulated with heatshrink.
I am still waiting for a 4 pin jack to arrive for the final hookup to plug in the active RF probe, and also have a black hinged handle ordered for the top of the cabinet.
(I do not claim that this tracer meets UL or any other safety standards, but it is only for my use, and I know where and how I'm using it.)
Number of posts : 526
Re: Another Homebrew Signal Tracer Project
Post by Wildcat445 on Mon Nov 10, 2014 5:09 pm
Nice job. I wish I had that ability.
Number of posts : 5166
Post by Ragwire on Mon Nov 10, 2014 7:45 pm
Thanks. I bet you could do it or better if you had the time. You have probably forgotten more about vintage electronics than I ever learned.
Post by Dr. Radio on Sat Nov 15, 2014 11:47 pm
You sir, have some serious talent there! Amazing work.
Post by Ragwire on Sun Nov 16, 2014 12:46 pm
Thanks, doc!
I finally got the handle on the top and the 4 pin jack for the active tube probe. Yay...all done!
I'm a test equipment junky. Laughing
Post by Wildcat445 on Sun Nov 16, 2014 1:31 pm
Frank seriously needs one of these things. I admire that kind of work. I just don't have that in me. I wish I did.
Post by Ragwire on Mon Nov 17, 2014 10:34 am
Frank can build one or pick up an Eico 147a for not too much. They usually work after recapping. I never gave much thought to tracers because I had a scope and signal generator and a few VTVMs with RF probes, but after the first time using one to troubleshoot, I don't want to be without one. They work great.
