WHAT EVER HAPPENED TO CHANNEL 1?
Post by Guest on Wed May 14, 2014 9:01 am
http://www.tech-notes.tv/History&Trivia/Channel%20One/Channel_1.htm
Re: WHAT EVER HAPPENED TO CHANNEL 1?
Post by Marco-ni on Wed May 14, 2014 10:48 am
""""" WHEN A TELEVISION RECEIVER IS PURCHASED in the United States, you can take it anywhere in this country, plug it in, pull up the "rabbit ears," and tune in a station. That is possible because we have national broadcasting standards that are common throughout the country. Yet, one time commercial television was going to be introduced to the American public without standards. Fortunately, that "experiment" ended before it even started. But let's not get ahead of the story! """
In Québec we have no longer this signal now.. we need a converter or a cable provider Sad
For the channel 1. i don't know , no one use it..
Marco-ni
Number of posts : 42
Registration date : 2014-03-31
Post by Guest on Wed May 14, 2014 10:53 am
It's the same in the USA.
Post by Marco-ni on Wed May 14, 2014 10:59 am
too bad because we can't receive a normal signal. I mean for the local stations....Sad thank you for your comment MEZLAW Wink
Marco-ni
Post by Wildcat445 on Wed May 14, 2014 11:41 am
It is amazing to me that TV was developed at all. No computers, just good old American ingenuity.
Post by Marco-ni on Wed May 14, 2014 12:01 pm
I agree Wildcat . However,, what was the use for the channel 1 ? the question is good.
Marco-ni
Post by Wildcat445 on Wed May 14, 2014 5:31 pm
If I understand correctly, Channel 1 is used as the Intermediate Frequency (IF) in TV. I don't remember the frequency, so perhaps Bill or Doc Radio could chime in and enlighten us. I am going on memory here, so I am subject to being wrong.
Post by Guest on Wed May 14, 2014 5:56 pm
From the article in my original post;
RCA"s experimental station quickly received a permit for one of those new television allocations and selected Channel 1
This is what happened to channel 1.  Wink
Post by Marco-ni on Wed May 14, 2014 6:38 pm
MEZLAW wrote:From the article in my original post;
Okay but... No one, even RCA can't use this channel now if i'm not wrong.
Marco-ni
Post by 75X11 on Wed May 14, 2014 7:02 pm
Note the entry for May 20, 1940. http://www.bostonradio.org/timeline/timeline-40s
Post by 75X11 on Wed May 14, 2014 7:08 pm
An Interesting Sidelight, Look at the entry for July 30, 1943. If you bought into ABC's myth that the network was founded in 1953, this puts the lie to it. http://www.bostonradio.org/timeline/timeline-40s
Post by Guest on Wed May 14, 2014 8:02 pm
More info;
As a result of hearings held on March 18, 1940, the FCC assigned FM a continuous band of frequencies (done to simplify tuner design), and expanded the FM allocation to include the frequencies from 42 to 50 MHz. The new allocation included the 44 to 50 MHz band that had previously been assigned to Channel 1.
But that is not what happened to Channel 1! The television channels were renumbered with Channel 1 now assigned to the 50-56 MHz band and the remaining channels were shifted around the spectrum. But when the smoke cleared, the television industry had lost one channel, leaving it with 18 allocations.
Post by Resistance is Futile on Wed May 14, 2014 10:40 pm
Mezlaw! There you go clarifying up the muddy waters of guessing and speculation,with investigation and research and down right knowledge. Its just not copasetic I say!
Number of posts : 976
Post by Bill Cahill on Thu May 15, 2014 1:14 pm
The reason for channel 1's failure is simple. The frequencies were too close to channel 2, and, were causing interference, so, in 1948 it was eliminated.
Number of posts : 4594
