Replacement 67 1/2 Volt "B" Battery
Post by Guest on Mon Apr 28, 2014 3:22 pm
It uses seven 9 volt transistor radio batteries
"B" Battery
What do you think?
Re: Replacement 67 1/2 Volt "B" Battery
Post by 35Z5 on Mon Apr 28, 2014 5:12 pm
Those things don't really care, either seven or eight will be fine...
Probably work almost as well on six...
Number of posts : 461
Post by Guest on Mon Apr 28, 2014 5:53 pm
I should have been more specific. What do you think of the battery case for the price. I know the voltage/current will be fine for the application. I can't believe they show a picture of the battery voltage NOT under load!
Post by 35Z5 on Mon Apr 28, 2014 7:08 pm
B+ load isn't that important when talking battery portables, it's usually a couple ma at most... The average six transistor radio of the '60s was 5x that, those generally chewed up batteries every couple weeks...
Post by 75X11 on Mon Apr 28, 2014 7:46 pm
I have one.  I use it in my Motorola 5A1.  Big Lots had a sale on Ray O Vac 9v's when I got it.
Post by Tony V on Mon Apr 28, 2014 7:48 pm
This guy has been selling these on Ebay for years and haven't seen any complaints about the quality of the product. If I had a radio that required these I would buy one. The cool thing is that its reusable.
Number of posts : 663
Post by 75X11 on Mon Apr 28, 2014 8:34 pm
A while back there was also a seller in Austria that had an eliminator that used 2 C cells and a switching power supply. I don't know how noisy such a unit would be. It weren't cheap.
Post by Dr. Radio on Mon Apr 28, 2014 8:37 pm
Mez,
To answer your question, they look nice. As stated that seller and their products have been around for some time.
It's up to you. I typically don't go that route for something that isn't seen. I just tape together a bunch of 9 volts and typical snap connectors are wired in series to yield whatever voltage I desire.
Post by Wildcat445 on Tue Apr 29, 2014 1:12 am
This may not work in the application you are talking about, but I have one of those power supplies that AES sold years ago to use as a battery eliminator. Would that be less trouble than dealing with several batteries for what you need?
Post by 75X11 on Wed Jul 02, 2014 7:03 am
An update, the pack I bought nearly 2 years ago still is operating on it's first set of batteries, Ray O Vac industrial 9v's. It suprises people to see a tube based portable come on and operate like a transistor unit, as most of them are static displays with no power supply.
