RCA 65x2
RCA 65x2
Post by willy3486 on Fri Mar 21, 2014 11:18 pm
Does anyone know if there is original RCA repair manuals online? I have a basket case 65x2 that I am working on. Between the mouse damage and previous user damage its a mess. But I have had some luck so I would like to see if I can get it going. I have the amp section going I think. I am having issues around the volume control and a IF transformer. There were two capacitors soldered on the center tab of the volume control. It was not wired exactly like the riders or bietmans diagrams are. I would like to see some RCA original manuals. Its in the sams but I don't have the sams for it. From 30 to 70 its hit or miss if I have that one.
Re: RCA 65x2
Post by Wildcat445 on Fri Mar 21, 2014 11:40 pm
I can't help you with a genuine RCA manual, but I have this model set at home, and we could use it for comparison if that would help. Good luck, Willy.
Number of posts : 5166
Re: RCA 65x2
Post by willy3486 on Fri Mar 21, 2014 11:45 pm
Wildcat445 wrote:I can't help you with a genuine RCA manual, but I have this model set at home, and we could use it for comparison if that would help.  Good luck, Willy.
If you have it apart does the volume control have two caps on it? One cap going to the ground and one cap to the 12sq7 tube and a 4.7 meg resistor on the same pin. If its not apart don't take it apart. I am in no hurry on this one. I probably won't look at it again until next week or longer. I may wait until after the radio meet even.
Re: RCA 65x2
Post by Wildcat445 on Sat Mar 22, 2014 12:11 am
My radio is at home, and I'm not. Until the middle of April. Sorry for the confusion, Willy.
Re: RCA 65x2
