RCA Loop antennas
RCA Loop antennas
Post by Ed in W. PA on Sun Mar 02, 2014 1:13 am
I have noticed on the RCA radio (16X4) that I am presently working on there is a small, flat and apparently honeycomb wound coil mounted inside the main loop antenna. It's function appears to be to induce a signal from a external antenna into the main loop. Looks like a nice feature. I'm new to the hobby and am curious to know more about these. Do other brands use these?
Ed in W. PA
Number of posts : 117
Re: RCA Loop antennas
Post by Dr. Radio on Sun Mar 02, 2014 8:26 pm
Assuming I am looking at the right schematic (seems this model could've had pushbutton presets or no presets), it looks like a simple way to couple an external antenna to the receiver's built in loop without "altering" what the RF amp "sees" circuit-wise so its characteristics stay the same.
Post by Dr. Radio on Sun Mar 02, 2014 8:40 pm
Oops, I guess I really didn't answer your question. Yes, other manufacturers used similar means to couple external antenna configurations. Most didn't put that much effort into them as a lot isn't needed, but RCA had the manufacturing equipment, the engineers and the money to spend, so they typically "over-did" even simple things.  Wink
