HP400C, AC VTVM
HP400C, AC VTVM
Post by Ragwire on Mon Jan 20, 2014 8:38 pm
I got this off eBay and I should have taken some "before" pictures.
Anyway, it cleaned up nice, eventually. It needed a new 6AK5 amplifier tube (V2, almost the first in the five tube amp string) because it was noisy. It tested OK, but in circuit, it was making the needle jump around. I also replaced the 6SQ7 (V1) just because I've never seen a good 6SQ7.
New handle...its for a guitar amp.
New caps for the old paper/wax and electrolytics.
Replaced several out of spec resistors and the 25K, B+ adjuster potentiometer. It was frozen and would not turn. I had to order that because I only have some 1/2 watt ones around and I think this was a 2 watt.
There was a tiny nut rattling around inside the meter movement housing that holds one of the spring clips that holds the glass.
Fixed that.
It needed new cabinet screws and speed nuts.
Replaced the power cord.
Cleaned switches and the other pot.
Paint touch up.
Replaced the filament rectifier with a silicon bridge and 2 ohm 20 watt dropping resistor.
Set B+ and filament voltage per spec, and went through the calibration procedure. I am very impressed with its rock steady RMS voltage readings as I dial though the wide band of frequencies from 20Hz to 2MHz...up to 300VAC and down to 1 millivolt full scale.  Cool
I like to say it's a "one trick pony," as it only measures AC voltage and nothing else...but boy howdy, it does its one trick very well!
Number of posts : 526
Re: HP400C, AC VTVM
Post by 75X11 on Mon Jan 20, 2014 8:45 pm
That's a real beauty!
Re: HP400C, AC VTVM
Post by Ragwire on Tue Jan 21, 2014 3:02 pm
Thanks. My scope is jealous....
Tek: "I can show waveforms and voltage!
HP: "Big deal, 99% of the time he only needs the voltage and I'm way faster to set up!"
Tek: "I'm pretty in blue!"
HP: "I have a calibrated amplified output!"
 Rolling Eyes
Re: HP400C, AC VTVM
Post by Resistance is Futile on Tue Jan 21, 2014 7:16 pm
Ragwire wrote:Thanks. My scope is jealous....
 Rolling Eyes
TeK: Yup! but ya cannot show distortion or harmonics or noise, HMMMMM. And a course you don't get that glow! LOL
OH did I ferget, I do Have Calibrated input- it says cal on the switches that are RED. affraid And The frequency I can see is much more that your limit.
Nice work on the refurb!!! That's a real Keeper!
Number of posts : 977
Re: HP400C, AC VTVM
Post by Ragwire on Tue Jan 21, 2014 11:47 pm
Thanks! I've been putting 'er to work already.
HP: "Well I can read the voltage of any frequency in a broadcast band receiver, and yes, I can indicate noise and harmonics just fine, along with their intensity with the proper setup...too many people only go out and buy new equipment these days rather than figure out how to make the VTVM work harder for them. Did you know when I team up with the old gray signal generator, that I'm also a capacitance and ESR tester?"  Wink
(Don't get me wrong, I love my scope, but I don't use it that often and could probably get by without it for the work I do.)
Re: HP400C, AC VTVM
Post by Ragwire on Wed Jan 22, 2014 12:03 am
Re: HP400C, AC VTVM
