GPX Boom box
GPX Boom box
Post by tube radio on Tue Jan 27, 2009 12:53 pm
GPX HM1836
3 CD Home Music System with AM FM Stereo Radio Cassette Recorder and Remote Control
Will not play CD'S anyone else had this problem and know how to fix it.
I am trying to fix it for my granddaughter.
Thanks for any information.
Tube Radio
tube radio
Senior Member
Senior Member
Number of posts: 184
Registration date: 2008-07-24
Re: GPX Boom box
Post by Resistance is Futile on Wed Jan 28, 2009 11:17 pm
Sometimes its dust inside the CD player.
Other times they just quit.
Number of posts: 627
Re: GPX Boom box
Post by Timaaay! on Thu Jan 29, 2009 1:26 am
Does the CD spin or do you get any info such as tracks, etc.?
Timaaay!
Senior Member
Senior Member
Number of posts: 150
Registration date: 2009-01-20
Re: GPX Boom box
Post by tube radio on Thu Jan 29, 2009 9:51 am
Timaaay
When I put 3 disc in and close it I get some noise from the drive but none from the speakers then when I press open it will not open and I turn the unit off and pull out the turn table to get the disc back out.
There is no information about the tracks.
Thanks for any help.
Lee
tube radio
Senior Member
Senior Member
Re: GPX Boom box
Post by Timaaay! on Thu Jan 29, 2009 2:32 pm
Hi Lee,
I'd first try to clean the lens. There are special disks or kits to do this but if you can get a damp Q-tip in there with some denatured alcohol, wipe it off well. Also check the traverse assembly (there's a metal rod that the laser travels along and a gear that drives it) if CDs aren't recognized or won't play, dust or dirt may be impeding it's free travel. Just remember to put some grease back on it should you need to clean it.
Often times it's a broken drive belt that spins the disk itself. The sound you hear may be the laser moving. Try to see if the disk is actually spinning.
Don't overlook the obvious (such as a bad disk, etc.) but I'm sure you know this. Usually the biggest challenge is getting the darn thing open to service it. The only worse thing may be getting it back together. Very Happy
Assuming, once you open it, you don't see any broken parts, gears, clips, belts, etc. It could possible be an electronic issue such as an A to D converter, but it's usually not. It's almost always a mechanical problem.
I hope this helps and perhaps someone else had some input.
Timaaay!
Senior Member
Senior Member
Re: GPX Boom box
Post by tube radio on Thu Jan 29, 2009 2:52 pm
Thanks Timaaay
I will try your suggestions.
Lee
tube radio
Senior Member
Senior Member
Re: GPX Boom box
Post by tube radio on Fri Jan 30, 2009 8:15 pm
Thanks Resistance and Timaaay.
I took it apart and found the turntable out of alignment I loosended it up and adjusted it and cleaned the lense while I had it apart. put it back together and it seems to work ok.
Lee
tube radio
Senior Member
Senior Member
Re: GPX Boom box
Post by Timaaay! on Sat Jan 31, 2009 12:11 am
Great Lee! I know those boomboxes can be a real pain to open and get back together some times.
Now let's hope your granddaughter (Not sure of her age) doesn't use it to blast RAP music when she's over for a visit!
affraid
Timaaay!
Senior Member
Senior Member
Re: GPX Boom box
Post by tube radio on Sat Jan 31, 2009 8:03 am
My Granddaughter is 10 years old and she doesn't listen to rap music thank goodness.
Lee
tube radio
Senior Member
Senior Member
