Television Antenna's
Television Antenna's  Empty Television Antenna's
Post by Guest on Sun Sep 15, 2013 11:28 pm
I need to install a new TV antenna at my farmhouse, does anyone know much about this unit;
http://antennadeals.com/HD2605.html
Television Antenna's  Empty Re: Television Antenna's
Post by 75X11 on Sun Sep 15, 2013 11:56 pm
I have little experience with the current generation of antennae, but here is another source of reviews on the unit.
http://www.amazon.com/Lava-HD-2605-Antenna-Remote-Control/product-reviews/B002MW0K22/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Post by Dr. Radio on Mon Sep 16, 2013 12:11 am
Hi Larry,
Do what I did, build your own on the cheap!
https://www.youtube.com/watch?v=EWQhlmJTMzw
This is what I use for an amplifier:
http://www.amazon.com/Channel-Master-Outputs-Distribution-Amplifier/dp/B001PI09SE/ref=sr_1_1?ie=UTF8&qid=1378764307&sr=8-1&keywords=channel+master+4+port
Right now I have the home-brew antenna in the attic, coax run straight to the basement where it feeds the above amp. Amp feeds the bedrooms. I still have a tube tv with analog tuner, so then the feed comes into a Zenith (also sold under the LG name) digital converter which has by far the best decoding chipset.
I bought a Channel master antenna rotor (N.O.S. from the 1990's before they ruined them by sending them over to China to be manufactured). Eventually that will rotate the antenna in the attic.
Number of posts : 899
Post by Dr. Radio on Mon Sep 16, 2013 12:15 am
Oh, just to be clear--you only need the amp for looong coax runs or splits, otherwise the $5.00 or so you spend on antenna parts will work just fine!
Post by Guest on Tue Sep 17, 2013 12:14 am
Great links, I think I'll go that route! Thanks Joe. Very Happy
Post by tuberadiogeek on Wed Sep 18, 2013 12:28 am
I think i'll make me one of those for an FM radio antenna. I think i could make in a few hours when i get the time and scrounge up the materials.
Post by Marco-ni on Mon Mar 31, 2014 10:49 am
Unfortunately, here in Québec we have no antenna at all on top of the house or even on a tv since about 4 or 5 years except if you buy a booster ( kind of electronic box for capting the waves ).. and withis box we have about 6 channels ( local )...so we have now the tv pluggued by a cable provider..
PS: sorry for my poor English .
Marco-ni
Marco-ni
Number of posts : 39
Registration date : 2014-03-31
Post by 75X11 on Mon Mar 31, 2014 4:24 pm
I see You have ATSC signals much like the US. As far as antenna types go, I have found even the older types will work with a booster amplifier. So many people have given up their antennas for cable, for many it is re-learning old technology. And your English is just fine. We are glad to have you here!
Post by Marco-ni on Mon Mar 31, 2014 5:12 pm
75X11 wrote:I see You have ATSC signals much like the US.  As far as antenna types go, I have found even the older types will work with a booster amplifier.  So many people have given up their antennas for cable, for many it is re-learning old technology.  And your English is just fine.  We are glad to have you here!
Thank you for your response but........yes an older antenna with a booster - amplifier ( Obligation )..Before, We could capture the waves via the antenna directly. In my case it is not because I wanted to this famous cable but we have not the choice. It warned a few years already that they would be obliged to have the cable, or as you say, a booster - amplifier.. However, we do not capture many channels with the amplifier. we capture at most only 4 or 5 channels but these are only local stations. Wink
And for your information, I have a lot of antennas Very Happy.. I keep them all in that case of........Wink
Marco-ni
Marco-ni
