Handy way to read my old signal generator frequency
Post by Ragwire on Mon Jul 15, 2013 10:55 pm
Here's a handy little RF amp I whipped up this weekend. Now my old Heathkit signal generator's frequency can be read on a DMM on the Hz setting. Not as accurate as an expensive frequency counter, but far better than reading the analog scale of the generator. My DMM requires 0.7 V to register anything below 10 MHz, and 1V for higher than 10 MHz.
Number of posts : 526
Re: Handy way to read my old signal generator frequency
Post by Bill Cahill on Mon Jul 15, 2013 11:19 pm
Hey, great idea! Thanks for the tip...........
Number of posts : 4582
Post by Ragwire on Mon Jul 15, 2013 11:46 pm
Thanks! It works great. Tuning the generator gives me a nice digital readout of what I'm really feeding the radio circuit. Ought to be great for alignments.
Just a couple 2N2222 in parallel wired common emitter. Input and output X-fmrs are hand wound (and sloppy) at about 3:1 in and 1:3 out on ferrite rod, but air core should be fine. About 200 turns of #30 maget wire on the high Z sides. RC=~120 ohms, RE=~30 ohms, RC-Vcc =~2.5K, RB-Gnd =~560 ohms. Caps at input and emitter resister bypas are .01 microfarad. No promises this is the best way, but it works for me and was easy to design.
Post by Ragwire on Tue Jul 16, 2013 7:48 am
I should add that I use the input side of the amplifier to the radio because it has the blocking capacitor. The output is just for monitoring frequency to a meter.
