IF Transformer
IF Transformer
Post by oldfart45 on Thu Jun 13, 2013 3:15 pm
I am restoring a Clarion Model AC-320 Tombstone.
Just prior to first power-up, while running resistance tests, I discovered an open primary in the second I.F. transformer.
The Clarion P/N is G-1619; 120 ohm primary, 110 ohm secondary with variable cap on secondary only.
Do you have any suggestions regarding replacement? I have disassembled enough
to ascertain that the open is not at the lead connection on the coil.
Any help will be appreciated.
Don Rex
oldfart45
Number of posts : 1
Registration date : 2013-02-21
Re: IF Transformer
Post by mr_ed01 on Thu Jun 13, 2013 4:35 pm
You might check here:  http://www.oldradioparts.com/
mr_ed01
Number of posts : 97
