B and K 960 Transistor radio analyst dyna trace probe
Post by radio451 on Wed May 15, 2013 10:16 pm
Hi,
I recently acquired a B and K model 960 Transisitor Radio Analyst, it came without probes. In the manual it mentions a "dyna trace" probe to be used in the in circuit transistor tests. The parts list only lists a 3 foot red test prod lead ASM-127. Is this a special kind of probe such as is on some signal tracers or is it just a regular test lead.
I am new to transistor radio repairing as a hobby and would appreciate any info on this probe.
radio451
Number of posts : 5
Registration date : 2013-04-15
Re: B and K 960 Transistor radio analyst dyna trace probe
Post by Resistance is Futile on Thu May 16, 2013 2:50 pm
Check this video for simple operation.
http://www.youtube.com/watch?v=VHUjugwRoVk
a more detailed one also:
http://www.youtube.com/watch?v=9m2HwF37dJ8
Number of posts : 977
Thanks
Post by radio451 on Fri May 17, 2013 8:14 am
Thank you, but it does not show the probe being used. The Dyna Trace probe goes in the jack between the large knob below the meter and the first smaller knob below the selector switch. It is used for in- circuit transistor checking (it is placed on the base), and also for signal tracing. I had seen these videos and they are helpful.
radio451
Number of posts : 5
Post by mikehall on Fri May 17, 2013 2:22 pm
I sent you a PM.
mikehall
Number of posts : 35
Post by mikehall on Fri May 17, 2013 2:42 pm
For solid state (transistor) testing, just a multimeter probe should work since dc voltages are low. Google "dyna trace probe"
mikehall
Post by Resistance is Futile on Sat May 25, 2013 5:12 am
I have a probe I ran across but it is a B&K Dynaflex Probe. It has three needle pins on one end and a miniature three pin connector on the other. I have a B&K 160 Transistor tester and a B&K 520 Transistor tester, but it isn't for them.
Post by Bill Cahill on Sat May 25, 2013 10:45 am
I think it's for an osciloscope.
Number of posts : 4559
Post by Resistance is Futile on Sun Aug 25, 2013 8:06 pm
I found out that the probe is part of a Jud Williams transistor curve tracer Model A.
Which I forgot that I had. Embarassed
