another battery dimension qustion
Post by radioalfa on Thu May 02, 2013 1:30 pm
Since my last post about battery dimensions was easily answered if I had searched more, I spent more time trying to find the answer to this but no luck so far.
I need to make a reproduction of an Eveready 522, 45 volt B battery. It looks like they use 522 designation for current batteries.
Any idea of the dimensions of a 522. Better yet, has anyone found a suitable container to use to construct one?
Thanks,
Russ
radioalfa
Number of posts : 18
Registration date : 2012-10-28
Re: another battery dimension qustion
Post by Resistance is Futile on Thu May 02, 2013 4:56 pm
a 522 is a 9 volt.
what radio is it for?
there is a 722
look for EverReady 45 volt battery
Number of posts : 977
Post by Guest on Thu May 02, 2013 6:08 pm
I know where there are two 45 volts batteries for sale. They are in excellent condition case wise, dead but not leaking. I wonder if there is any value to opening them up to rebuild them. They should at the very least be good for models for making a new battery.
Post by Guest on Thu May 02, 2013 6:11 pm
Here are some reproduction cases you can download;
http://www.vacuumtubeera.net/Reproductions.html
Post by radioalfa on Thu May 02, 2013 9:21 pm
Thanks MEZLAW, that is where I found the image for the label I will use. It is the Eveready "B" 45 Volt label. The .gif file opens up quite big, so I can scale to any size.
As far as rebuilding an old one, I am not sure, but perhaps they can be filled with some 9 volts.
Resistance is Futile, I am using this for my Radiola III. This battery seems to be the right period. I will take a look at the 722.
radioalfa
