Battery dimensions
Battery dimensions
Post by radioalfa on Wed Apr 10, 2013 2:24 pm
I am currently working on making a reproduction "A" battery, using an image of a label for an Eveready 7111.
The aspect ratio of the image will produce a label for a 3" dia tube that is 6 inches tall, or for a 2 1/2 inch tube, one that is about 5' tall. So far I have made one 3" ida, and will make a 2 1/2" tonight. I think the 2 1/2 will look better, but might be a bit short.
Any help on what the original dimensions were would be appreciated.
Thanks!
Russ
radioalfa
Number of posts : 18
Registration date : 2012-10-28
Re: Battery dimensions
Post by mr_ed01 on Wed Apr 10, 2013 4:14 pm
from Radiomuseum.org Model: Radio "A" Battery 7111 -
Eveready, National Carbon
Dimensions (WHD) 2.6 x 6.6 x 2.6 inch / 66 x 168 x 66 mm
mr_ed01
Number of posts : 96
Post by oldgoaly on Wed Apr 10, 2013 4:24 pm
2.6 x 6.6 x 2.6 inch / 66 x 168 x 66 mm is what the Radio museum says http://www.radiomuseum.org/r/eveready_7111.html
I have no idea where my 2 batteries are hiding. Rolling Eyes
you beat me to it, yep it took 10 minutes to walk thru and not see them.
oldgoaly
Number of posts : 100
Post by radioalfa on Wed Apr 10, 2013 9:03 pm
Thanks for your answers, I think I should had been able to find that myself:)
Now the challenge is to edit my image so that the proportions are correct.
radioalfa
Post by oldgoaly on Wed Apr 10, 2013 11:16 pm
What program are you using? might make a interesting thread! I know I'd like to know more. I have a vintage Milwaukee planishing hammer I'd like to copy the original decal, and it is on a curve. how can you flatten it out with out loosing the shape? just one of many things I wish I could do but......
oldgoaly
Post by willy3486 on Thu Apr 11, 2013 8:31 am
oldgoaly wrote:What program are you using? might make a interesting thread! I know I'd like to know more. I have a vintage Milwaukee planishing hammer I'd like to copy the original decal, and it is on a curve. how can you flatten it out with out loosing the shape? just one of many things I wish I could do but......
Years ago they made a hand scanner that you could roll across something. If someone had one they could scan a curved surface and the label would be saved as flat. I don't have one but I remember setting these things up.
Number of posts : 1420
Post by radioalfa on Thu Apr 11, 2013 8:41 am
I found the image for the label here;
http://www.vacuumtubeera.net/Reproductions.html
I am using Paint to change from a gif to a bmp. So far I have added some area to the top and bottom to give me a label that is the right diameter, and now about 5.5 inches tall.
So to answer oldgoaly, no idea how you can start from scratch.
radioalfa
Post by oldgoaly on Thu Apr 11, 2013 2:04 pm
My idea was to take a pic of it then modify it or unroll it, bet a kid could do it..... arrgggh! pirat
oldgoaly
Post by 75X11 on Thu Apr 11, 2013 4:22 pm
I remember seeing hand scanners too, out of curiosity, I checked on Ebay, and there are a number of them new and used under computers then scanners then keywords hand scanner. $25 and up. That will be for my "one of these days" file.
Post by radioalfa on Fri Apr 12, 2013 8:56 pm
oldgoaly wrote: bet a kid could do it..... arrgggh! pirat
so true:)
perhaps some one talented with photoshop could do it
radioalfa
