Cobramatic tonearm setting down too soon
Post by PhonoBrit on Mon Apr 08, 2013 3:20 pm
This cobramatic unit http://i.imgur.com/Kd7qlf4.jpg tonearm is setting down just before it should on the 7" setting. How do I adjust the arm to set down on the records edge?
Thanks!
PhonoBrit
Number of posts : 92
Re: Cobramatic tonearm setting down too soon
Post by fixinmyphono on Mon Apr 08, 2013 7:09 pm
Send me your e-mail addy and I'll send you some service data which may help you...
fixinmyphono
Number of posts : 204
Post by fixinmyphono on Tue Apr 09, 2013 6:35 pm
Did the info help?
fixinmyphono
Post by PhonoBrit on Thu Apr 11, 2013 7:16 pm
fixinmyphono wrote:Did the info help?
Hmm, i don't appear to have gotten an email from you.
PhonoBrit
Post by fixinmyphono on Thu Apr 11, 2013 7:31 pm
ok I tried once more let me know...
fixinmyphono
Post by PhonoBrit on Thu Apr 11, 2013 7:33 pm
fixinmyphono wrote:ok I tried once more let me know...
Got it this time! Thank you. Smile
PhonoBrit
Post by fixinmyphono on Thu Apr 11, 2013 7:43 pm
No problem hope it helps
fixinmyphono
Post by PhonoBrit on Thu Apr 11, 2013 8:10 pm
Ok, the manual pointed me in the right direction for the adjustment screw, so that is all fixed now. However, I need to remove the platter and can't see any clip holding the platter in place. Am I missing something here?
PhonoBrit
Post by fixinmyphono on Thu Apr 11, 2013 8:47 pm
show us a picture of it if you can...mine lifts right off
fixinmyphono
Post by PhonoBrit on Fri Apr 12, 2013 4:40 pm
fixinmyphono wrote:show us a picture of it if you can...mine lifts right off
Right here... http://i.imgur.com/ereFA1T.jpg
PhonoBrit
Post by fixinmyphono on Fri Apr 12, 2013 8:05 pm
Looks the same as mine try a few tiny dabs of thin oil around the spindle shaft let it soak and try prying up evenly around the edges of the platter...
fixinmyphono
Post by Tony V on Fri Apr 12, 2013 9:31 pm
Make sure when you pull the platter off that your careful with the tip of the spindle as they snap off easily.
Number of posts : 648
Post by PhonoBrit on Sat Apr 13, 2013 7:10 pm
The oil did the trick, thanks guys. Smile
PhonoBrit
Post by fixinmyphono on Sat Apr 13, 2013 7:45 pm
Good deal How to the idlers look?
fixinmyphono
Post by PhonoBrit on Sat Apr 13, 2013 8:14 pm
They look ok-ish, lubed the motor and testing for speed variance right now.
PhonoBrit
Post by PhonoBrit on Mon Apr 15, 2013 3:38 pm
Oh does anyone know the part number for this Cobra Matic stylus?
http://i.imgur.com/raXk3uX.jpg
PhonoBrit
Post by fixinmyphono on Mon Apr 15, 2013 7:09 pm
heres a chart with it
http://www.west-techservices.com/images/needle.jpg
fixinmyphono
Post by PhonoBrit on Tue Apr 16, 2013 3:58 pm
Thanks, looks like the needle isn't replaceable and that the entire cartridge must be swapped out.
PhonoBrit
Post by fixinmyphono on Tue Apr 16, 2013 6:09 pm
voice of music website sells them Smile
fixinmyphono
Post by glennetching on Wed Jun 11, 2014 10:48 pm
i originally had a problem with my phonola 958 the tone arm setting down an lifting right back up an shutting off ..i took apart an oiled everything ..now reject does'nt work ,,record does'nt drop ..what could be ?..ps can the center spindle be pulled up an lubed?
glennetching
Number of posts : 2
Registration date : 2014-06-10
