Arvin Twin Speaker
Arvin Twin Speaker
Post by Guest on Fri Apr 05, 2013 6:34 pm
I did pick up this 1957 Arvin radio today;
ARVIN INDUSTRIES INC. TUBE RADIO MODEL NO. 3561
6 tube; 35W4, 50C5, 12AV6, 12BE6, and two 6BJ6's
Nothing special, it just caught my eye and the plastic case is in nice shape.
Re: Arvin Twin Speaker
Post by Dr. Radio on Fri Apr 05, 2013 6:40 pm
I wouldn't say nuthin' special... Cool
Twin speaker, cool "tone register dial" and it's a 6 tuber---meaning it has a RF amp stage....it will be a hot performer if restored properly!
Laughing
Post by Bill Cahill on Fri Apr 05, 2013 7:24 pm
Personally, I think two is always better than one.
And, I agree on the rf stage. Especially if it's tuned.
Number of posts : 4560
Post by Guest on Fri Apr 05, 2013 8:00 pm
I was just thinking about a radio like that last week and decided I wanted one. I didn't think I would find one this quick. Next, I need to find the time to work one a few of these finds.
Post by Resistance is Futile on Sat Apr 06, 2013 11:50 am
Sometimes 6 tube radios have an audio driver added and use two finals in push-pull audio or parallel so there is no added RF. stage.
Number of posts : 977
Post by Wildcat445 on Sat Apr 06, 2013 7:29 pm
That partiular radio uses the 6BJ6's for an RF amp and the IF amp. It has no extra tubes in the audio. It should be a hot performer when it is restored properly. Have fu.
Post by Guest on Sun Apr 07, 2013 11:09 am
Wildcat445 wrote:That partiular radio uses the 6BJ6's for an RF amp and the IF amp. It has no extra tubes in the audio. It should be a hot performer when it is restored properly. Have fu.
Yes, I checked the schematic when Cliff first pointed out the possibility that it might not be.
Post by rdusel on Tue Apr 09, 2013 12:19 pm
Very nice. I like the unusual dial scale for the tone.
Arvin made some neat radios.
rdusel
Number of posts : 11
Registration date : 2013-03-25
Post by Guest on Tue Apr 09, 2013 10:05 pm
This radio was also sold under the Sears name.
Post by Guest on Sat Apr 13, 2013 11:30 am
Here is the Arvin;
Post by Guest on Sat Apr 13, 2013 11:32 am
The Arvin chassis;
Post by Tony V on Sat Apr 13, 2013 1:43 pm
Very unusual styling for an Arvin but cool. I like the tone and station locations.
Number of posts : 633
Post by Guest on Sat Apr 13, 2013 2:02 pm
Tony, I picked this up in a little shop on Rt.11 in Verona. I'm sure you've been there.
Post by Bill Cahill on Sat Apr 13, 2013 3:26 pm
Nice looking radio. Not bad for an Arvin.
Reminds me of an AM-FM Airline I own.
Unusual style case. Push button opreration, speaker on top sticking out. Bottom front is volume control, dial, and, tunning.
It's actually got fairly good fidelity.
Post by Tony V on Sat Apr 13, 2013 6:51 pm
Yes, i know the shop you speak of. I also go to the "Factory" in Verona although its been some time since i've been to either one. Waynesboro has a couple of shops with the best one being Laynes on N340.
Looks like the Arvin has a nice set of speakers for a "twin" set-up as most of them had smaller speakers. It should sound nice once its gone over.
Post by Dr. Radio on Sat Apr 13, 2013 7:33 pm
I checked out the schematics for this, found it in the 1957 Beitman's.
This is actually a very nice set. If properly gone-over, it will not only pull-in the distant stations thanks to the tuned RF stage, but sound great as well!
It also has a dial light to illuminate the scales, a phono jack input and a 3 section electrolytic for filtering.
Nice score Very Happy
Post by Guest on Mon Apr 15, 2013 6:57 pm
I had to bundle with a couple other items to get it down to $15, but I think it was worth it! Very Happy
Post by Guest on Sat Aug 17, 2013 1:12 am
I finally got a chance to start working on the Arvin and what a pain in the butt it's been so far. It was completely dead and would not come up on the variac, so I decided to check all 6 tubes. No problem with the tubes, so I checked the switch and that was OK too.  Well I decided it had to be an open trace on the printed circuit board but that checked out just fine as well. Then I decided to do a volteage check from one side of the plug through each tube reading source voltage until I hit zero. THE TUBE SOCKET IS BAD!!! I'm going to try and repair the tube socket because it has an offset on all pins. Where it solders into the printed circuit is a larger circumference than the circumference of the pins. I hate PCB's and I hate these tube sockets even more!
Post by Bill Cahill on Sat Aug 17, 2013 4:55 pm
May I see pics of bad socket? There's a slight chance I may have one. I do have some PCB sockets.
Post by tuberadiogeek on Sun Sep 01, 2013 1:25 am
I have a few sockets i could pull out of a junk chassis. They are black plastic from the 50's. However they were not for a PCB radio but still may work. I have some octal,7 and 9 pin mini sockets.
Number of posts : 665
Post by 75X11 on Sun Sep 01, 2013 5:12 pm
I've found this material to be handy to repair torn broken or lifted traces on PCB's.
http://www.amazon.com/Copper-Foil-Tape-CR-Laurence/dp/B006JCLODA/ref=sr_1_29?ie=UTF8&qid=1378069648&sr=8-29&keywords=copper+tape
Also, this old thread of mine shows how to make a manual solder extractor clean out discrete PCB solder connections, with less afterwork or reheats. Flux is also a must.
http://www.tuberadioforum.com/t1766-for-the-solder-extractor
Post by Guest on Mon Sep 16, 2013 11:17 pm
This was not damaged at the circuit board trace, the socket itself was bad. I did find a 7 pin socket that will work.
Thanks to all.
Post by Bill Cahill on Tue Sep 17, 2013 4:36 am
Glad you found a socket that will work. Good luck on restoration.
Please keep us informed................
Post by Wildcat445 on Tue Sep 17, 2013 6:55 am
I exercise every "good" word I know when I have to change a tube socket on a PCB. Good luck.
Post by Bill Cahill on Tue Sep 17, 2013 8:37 am
My words come out in fours. Letters, that is...............Very Happy
