Cable channels on an antique CRT television set
Post by Wildcat445 on Sat Feb 23, 2013 1:25 pm
Okay, you antique tv guru dudes, here is a newbie (to tv) type question.
How do I get cable channels above channel 13 on an old tv set? I am seriously considering getting an older, circa 1950-ish, tv set working to complement my radio collection. I have been dinking with radios for over 40 years, but tv sets scare me like lots of other guys, I guess. That nasty high voltage and all. But I have tentatively decided to "take the plunge" and see if I can find one and actually make it work. On satellite, I have a box and I change the channel with the satellite receiver. So there would be no problem using one of the older sets with satellite. With cable, there is no box. So how would I get cable channels without the box? Can I use one of those converters that you use with antenna to get cable channels? I am looking at an old RCA tv and my wife thinks that I would be unhappy if all I could watch was the VCR. She may have a point. There were UHF converters made in those days, but I would like to be able to avoid using one if a more modern alternative is available.
Thanks for your input.
Re: Cable channels on an antique CRT television set
Post by Dr. Radio on Sat Feb 23, 2013 2:07 pm
You simply need some sort of external converter or tuner...period.
Something needs to be able to decode or tune the cable and then send it out via VHF to channel 3 or 4 something the old tv is capable of tuning.
Post by mr_ed01 on Sat Feb 23, 2013 10:56 pm
Could route the cable through an old cable-ready VCR then watch TV channel 3 or 4.
mr_ed01
Number of posts : 99
Post by Dr. Radio on Sat Feb 23, 2013 11:11 pm
mr_ed01 wrote:Could route the cable through an old cable-ready VCR then watch TV channel 3 or 4.
Yes, you are correct...but again...you still have that "middle man" to do the work. Very Happy
Post by N7ZAL on Sun Mar 24, 2013 7:49 pm
Yes that would be a good solution and certainly cheap enough. The VCR could be stripped down to the modulator section and wouldn't take up much real estate.
N7ZAL
Number of posts : 501
