twistlock caps replacement
Post by Ben Delk on Wed Feb 13, 2013 3:55 pm
http://www.nostalgiaair.org/Resources/260/M0012260.htm
I have a Twistlock multi-section (3 section) electrolytic Iím attempting to replace with single caps but Iím trying to understand what they are doing here. This cap is dead as a wedge on all 3 connection. The cap is mounted on the chassis top but insulated on a wafer. There is a wire from the transformer which appears to be (+) attached to one of the three twistlocks. Could they be applying incoming (+)voltage to the cap housing and negative(-) out thru the 3 center taps? Please pardon my confusion, this is the first twist lock I have attempted to replaced with single caps.
Thanks,
Ben
Ben Delk
Number of posts : 443
Re: twistlock caps replacement
Post by mr_ed01 on Wed Feb 13, 2013 4:09 pm
The center tap of the High voltage winding is attached to the twist-lock tab which is insulated from the chassis. This is the most negative point. The twist lock tab is connected to 'chassis ground' through resistors R15 (180 ohms) and R12 (10 ohm). This develops the bias voltage for the 6K6 audio output stage and the detector/Avc 6SQ7. The negative on all 3 of your replacement electrolytics will connect to the tab.
mr_ed01
Number of posts : 98
Post by Ben Delk on Wed Feb 13, 2013 4:30 pm
Thank you sir.
ben
Ben Delk
