Capacitor question
Capacitor question
Post by orthophonio on Thu Jan 24, 2013 9:59 pm
I know this is a 'radio parts' forum but this question is related to an RCA EY-4 phonograph. I'm sure the part is used in radios as well.
I am about to order the capacitors so I can recap the amp and there's one with a value of .01uf +10% 200volts. What's the '+10%' all about and what capacitor would I order that would be the same value.
Thanks-
Scott
orthophonio
Number of posts : 7
Registration date : 2013-01-10
Re: Capacitor question
Post by jukeboxman on Fri Jan 25, 2013 12:25 am
Hi Scott it simply means 10 percent margin of error .
most of just order 630 volt replacements
GARY
(Jukebox Man)
jukeboxman
Number of posts : 135
Post by orthophonio on Fri Jan 25, 2013 12:31 am
jukeboxman wrote:Hi Scott it simply means 10 percent margin of error .
Thanks jukeboxman. So does that mean I should just order a .01uf 630volt capacitor or do they actually make that same type of capacitor with a +10% something or other?
orthophonio
Number of posts : 7
Post by jukeboxman on Fri Jan 25, 2013 1:30 am
yes .01 630 volt will be fine ,ignore the 10 percent
GARY
(Jukebox Man)
jukeboxman
10% something or other....
Post by Steve Myers on Tue Jan 29, 2013 3:00 pm
When a value is given as in your case 10% that means the value of the capacitor can vary as much a 10% one way or the other. They were not built as precesion components and the value could vary + or - 10%. I hope this help you understand. This is my understanding anyway.
Steve
Steve Myers
Number of posts : 16
Registration date : 2012-06-12
Post by GaryRabbitt on Wed Jan 30, 2013 2:40 am
Hi Scott.
When ordering, why not order 5 or 10 more to keep on hand for your next project? Buying a few extra of each value, you will soon have a small stock of caps on hand, saves time/shipping in ordering for each set you do.
Good lcuk on your project.
GaryRabbitt
Number of posts : 96
Post by Resistance is Futile on Wed Jan 30, 2013 3:09 am
10% doesn't apply to the voltage. Just capacitance.
Number of posts : 977
Post by Guest on Wed Jan 30, 2013 9:59 pm
Here are a few more references to pick through.
http://www.bing.com/images/search?q=Capacitor+Value+Chart&qpvt=Capacitor+Value+Chart&FORM=IGRE
