Motorola 56W
Motorola 56W
Post by Guest on Thu Jan 24, 2013 8:10 am
I have a Motorola 56W that I plan to re-cap. C1 is a 40-30-30 @ 150WVDC and I found the following caps'
47-47-47 @160WVDC
33-33-47 @160WVDC
I thought I would use the 33-33-47 and watch which section I wired to where, which one would you use?
Here is a link to the caps;
http://www.radiodaze.com/category/355.aspx
Re: Motorola 56W
Post by Dr. Radio on Thu Jan 24, 2013 10:04 am
Larry, the 33-33-47 is the ideal replacement. Those are the modern equivalents to the original values. Just curious, why not just install modern discrete separate units?
Re: Motorola 56W
Post by Guest on Thu Jan 24, 2013 10:20 am
No reason other than to install a similar part. Since this is not in a can above the chassis I might just install separate caps.
Re: Motorola 56W
