Eico 667 Question
Eico 667 Question
Post by Johnnysan on Sun Dec 30, 2012 4:53 pm
I'm working on an Eico 667 that is very clean and everything seems to be OK. Resistors test fine; electrolytics were OK but got replaced anyway. All connections, switches and controls look fine also. It tests many tubes and everything seems to be functional, but, it will not test 1L6 tubes (almost no deflection with a new tube). The only thing I can think of is that the set-up data for this tube is wrong.
Has anyone run across this problem?
Johnnysan
Number of posts : 17
Registration date : 2009-01-02
Re: Eico 667 Question
Post by Mike C. on Tue Jan 22, 2013 7:12 pm
Johnnysan,
What version of the Eico data are you using?I have tons of charts for the 667,I might be able to suggest alternate settings.
Mike C.
Number of posts : 7
Registration date : 2013-01-22
