Simple Easy To Build SS TX
Post by 35Z5 on Sat Dec 29, 2012 2:55 pm
Excellent performer as well...
This schematic assumes a 9V battery, but it can be operated on a wallwart or other AC P/S as well(have schematics for other versions)... When antenna is properly tuned it only draws 11ma and assuming there is no 1000 or 1230 local, has at least 100ft of crystal clear range on a 10ft antenna...
http://amradio.freeiz.com/transmitter/simpleSSTX.jpg
Number of posts : 461
Re: Simple Easy To Build SS TX
Post by samd on Sat Dec 29, 2012 6:18 pm
Looks good (& simple)
samd
Number of posts : 9
Registration date : 2010-10-18
Post by 35Z5 on Thu Jan 03, 2013 4:49 pm
There is a screw-up on this schematic, pin#3 on the LM386N should be grounded...
Post by 35Z5 on Sun Jan 06, 2013 4:08 pm
Here's a LM386N version complete with P/S... Schematic is almost correct, Embarassed add the 470pf to ground on pin #2...
Use parts info from first schematic if you need 1.228Kc...
http://amradio.freeiz.com/transmitter/386txps.jpg
