Precision 912 Tube Tester
Re: Precision 912 Tube Tester
Post by Guest on Mon Apr 01, 2013 11:20 pm
Nice tester Jerry!
I got the 912 for $75, it's in great shape but is missing the 9 pin adaptor.
Post by willy3486 on Tue Apr 02, 2013 9:31 am
I have had good luck with my precision. I also have a hickok but I use the precision. I need to go through the Hickok and find a case for it.
Number of posts : 1420
Post by oldgoaly on Wed Apr 03, 2013 10:26 pm
Well after reading this thread I'm glad I picked up the 912, I need another tube tester like a another hole in my head. But could not pass the deal up a box of good tested tube and a 912 (missing lid) for 50$ At least the wife didn't complain she was the one that found the ad for the speakers AK-m for 45$, and another horn speaker for 40$. even helped carry them to the truck!
oldgoaly
Number of posts : 100
Post by 75X11 on Wed Apr 03, 2013 10:44 pm
Nice catch! If I had called that shot, it would've been long gone when I went to inquire.
Post by Guest on Wed Apr 03, 2013 10:52 pm
75X11 wrote:Nice catch! If I had called that shot, it would've been long gone when I went to inquire.
I know, that's what usually happens to me. This time I got lucky. I have an updated roll chart that was never installed and dated Novenber 1946. Some examples; the installed chart does not list the 35W4 and only the 50A5. The newer roll chart does show the 35W4 and the 50B5 but not the 50C5. I would like to get a more current chart and the 9 pin adapter for it.
Post by 75X11 on Thu Apr 04, 2013 12:08 am
Well you got the tree, now for the trimmings!
Post by oldgoaly on Fri Apr 05, 2013 1:47 am
[img][/img]
ok this is 4th time last two times I knocked myself right off the site???
hey that looks like it worked! affraid so 4th time is the charm....or is the 5th?
oldgoaly
Post by Guest on Fri Apr 12, 2013 7:05 pm
Does anyone have a chart for the 912 newer than November 1, 1946?
I have 2 charts, one is the original from March 15, 1943 and the other is November 1, 1946.
I don't want to take your chart but would like to get some information from it, such as; the settings for a 50C5. My "newest" chart only shows setting for a 50B5.
I went to BAMA and they have the manual but no chart information.
Post by Greg Davis on Sun Feb 09, 2014 12:49 pm
Here are the settings for the 50C5:
A=6
B=11
C=28
D=27
E=1
F=6
Depress J
(50C5 Must show short on B-E)
(50C5 Fil. Cont. - Depress C)
(50C5 Grid Short Test - Depress B-E together)
Greg Davis
Number of posts : 284
Post by Guest on Sun Feb 09, 2014 1:11 pm
Thanks Greg.  Very Happy
Post by Guest on Sun Feb 09, 2014 1:18 pm
Now I need to find a 9 pin adapter. I'm sure that will not be easy.
Post by Greg Davis on Sun Feb 09, 2014 1:23 pm
Mine came with the Coletronics Model B-16. Want to borrow it?
Greg Davis
Post by Greg Davis on Sun Feb 09, 2014 1:41 pm
In case you need any other information from the updated roll chart, here's a PDF of the book form of the roll chart that came with my unit.  It also came with two "Tube Test Data" spiral bount booklets that appear to be dated 2-15-71 and 2-15-73 respectively.
Precision 9XX Roll Chart G2B.pdf
Warning, it is a 21MB file.
Greg Davis
Post by Guest on Sun Feb 09, 2014 1:43 pm
Thanks, but I'm good for now, I have several tube testers and I don't always use the 912. I may try to Google that part number.
Post by Guest on Sun Feb 09, 2014 1:46 pm
Thanks for the roll chart PDF that's a big help.  Very Happy
Post by Guest on Sun Feb 09, 2014 2:13 pm
Greg Davis wrote:Mine came with the Coletronics Model B-16.  Want to borrow it?
Unless I read something wrong, the instructions say to plug the Coletronics Model B-16 into the 9 pin socket. Maybe you have a newer revision which has a 9 pin socket?
Post by Greg Davis on Sun Feb 09, 2014 2:15 pm
Yes, now that you mention it, it does. In the upper right corner. Guess my addon wouldn't help you after all.
Greg Davis
Post by Guest on Sun Feb 09, 2014 2:43 pm
There is supposed to be a 9 pin adapter if I understand it correctly which plugs into one of the other tube sockets.
Post by Guest on Sun Feb 09, 2014 2:51 pm
Here's a nice looking one;
http://www.ebay.com/itm/Precision-Mode-Series-912-Tube-Tester-/350990669113?pt=LH_DefaultDomain_0&hash=item51b8ac9539
Like mine it does not appear to have a 9 pin socket. Too much money in my opinion.
Post by Greg Davis on Sun Feb 09, 2014 2:56 pm
Here's what mine looks like:
Greg Davis
Post by Guest on Sun Feb 09, 2014 2:57 pm
OK.....I see the brown 9 pin socket in the extreme upper right hand corner.
Post by Greg Davis on Sun Feb 09, 2014 3:19 pm
I realize it's not much help, but here is a picture of how the 9-pin is connected in.
Greg Davis
Post by Greg Davis on Sun Feb 09, 2014 3:37 pm
This may be the information about the 9-pin adapter you are seeking:
http://www.jogis-roehrenbude.de/Roehren-Geschichtliches/Roe-Pruefer/Precision-910/Adapter.pdf
Greg Davis
Post by Guest on Sun Feb 09, 2014 4:22 pm
It is but it looks to be too effort when I have better tube testers now. I still may decide to make the modification, which is pretty simple, if I ever find the adapter.
Post by Greg Davis on Sun Feb 09, 2014 7:28 pm
Here is the Tube Test Data book that accompanies the Roll Chart in the prior post.  This is the one dated 02-15-73.
Tube Test Data 02-15-73.pdf
Warning, this file is 36.7MB.
Greg Davis
