Eico 147A Signal Generator
Post by Guest on Thu Nov 01, 2012 3:57 pm
I also came across this signal generator purchased at the same time as the audio generator.
http://www.radiomuseum.org/r/eico_signal_tracer_147a_147_a.html
Has anyone restored one of these?
Re: Eico 147A Signal Generator
Post by harold wright on Sat Nov 03, 2012 9:05 am
I have not restored one but have done minor repairs to mine. I use it a lot on bench. It is quite versatile.
Harold
harold wright
Number of posts : 51
Registration date : 2012-10-14
Post by willy3486 on Sat Nov 03, 2012 3:10 pm
I have not restored one but I do have one of the cap checkers about the same time I just bought. I have a good one I actually use and I just bought it for the looks. Mine is one of the blue looking ones. I also want a few old tube type test pieces to restore. The parts manuals and user guides are out there easy to find. I don't think they should be that hard to fix, at least hopefully they won't be.
Number of posts : 1420
Post by Sal Brisindi on Fri Nov 23, 2012 5:31 pm
The Eico 147A is a signal tracer. Basically it has a high gain tube amplifier used in conjunction to trace the signal path from the RF stage to the audio stage of a radio. It also has a jacks to the audio transformer inside the tracer you can use if you have a bad audio transformer in the radio.
I have 1 or 2 but I have not restored mine.
Regards,
Sal
Sal Brisindi
Number of posts : 21
Post by Guest on Fri Nov 23, 2012 7:54 pm
I just noticed, I titled this thread as a Signal Generator instead of a Signal Tracer. I'm not sure why I made that mistake, (I know better) but thanks for bringing it to my attention Sal. Smile
Must have something to do with age! lol!
Post by Dr. Radio on Fri Nov 23, 2012 9:54 pm
Replace the caps, make sure the resistors have not drifted and make sure if that light bulb is burned out, try to get the same type in there as it is apart of the oscillator circuit.
Other than that, you'll have a nice piece of equipment for your bench Very Happy
