VLF ant
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
VLF ant
Of course this not SW but VLF. I'm making an antenna on a 3 ft. square form with taps at 14 turns, 28 turns and 42 turns. When I triangulate for the direction of the incoming sig is it the broadside of the loop that is the receptor side or the edgewise angle? I'm referring to VLF at 150 to 400 KHz. I need to know at which point of the compass is the direction of the incoming signal. I'm referring to the AM BC band portable radios with the rotating ferrite antenna on top for direction finding such as used on boats. Except that I'm using a DX-160. Thanks, OT.
oldtimer- Member
- Number of posts: 35
Registration date: 2008-04-12
Re: VLF ant
Hey Oldtimer . The edge of the loop picks up the signal.
Otherwise put, one horizontal cross arm will point exactly towards the station (and the cross arm on other side will point away from the station) .
Go to see another VLF'er on board. I work from REALLY low (natural radio /whistler stuff) all the way up through the Afro Euro bcast band/ beacons to 530 Kc.
FWIW, I live about 6 miles inland Boston and on a 75ft longwire 15 ft over a flat apt roof I get longwave B'casts on a number of ,if not "MANY", nights. Not always great, but there. I do get "lifts" at times where some of them come in pretty good.
When I set up at the beach (ie Salisbury, Ma or different beaches on Cape Cod) longwave bcasts boom in on just 75 to 200 ft of wire.
For the lower freqeuency stuff (ie SAQ Sweeden)I've run out 1500 or even as much as 2000 ft of wire and used a 100 ft bare copper wire saltwater ground radial for my return.For this work I use an Icom R-70.
And as sick as I am, I even LIKE lightning crashes (for my weather studies). My fully passive "7" Kc microphonic "system" (no amps /no batteries) gets South America at fair copy and North America quite well w/o much 60 Hz.
When I use the double amped / double graphic equalized version of the system, South America is VERY good and N. America STORMS in. I MIGHT also be getting some other stuff (Africa , Indonesia area,etc ) at "whatever" volume but am not sure- I can't really confirm these ones, although they are probably mixed in w/ the closer louder stuff (from S.and N. America).
On the amp'ed system, 60Hz is scrubbed out to near zero.
Overall quite good considering my antenna has 13.8Kv at about 20 ft on TWO sides .
de K
de K
krystallo- Member
- Number of posts: 36
Registration date: 2008-04-03
Re: VLF ant
Thanks for that. It's not like a longwire. You mentioned SAQ. Is that the alternator xmitter at 17.2 KHz? OT
oldtimer- Member
Re: VLF ant
Yes, SAQ is at 17.2 Kc. during several attempts I only got it once, VERY weak. But my Icom is not spec'ed to operate that low.I'm lucky I got it.
K
K
krystallo- Member
VLF
Het krystallo. A VLF translator is avail at Palomar Engineers. www.palomar-engineers.com Mod VLF-S $99. I hope to get one. They also said a vertical ant works for that freq. ( SAQ ). I'm going to try a loop and maybe a looong wire. Also I'm thinking of building a 2 meter square multi-loop ant. for lower freqs. with taps at 14-28 & 42 turns tapped at each 14 turn loop. I'm using 14 cond ribbon cable. A comeback from hams and listeners always welcome. OT
oldtimer- Member
Ant
You mentioned an antenna at " 13.8 Kv ". What's that? OT Also, what is " Noob " ? OT
oldtimer- Member
Re: VLF ant
The 13.8 Kv are the high voltage power lines . My apt is on a corner , so we have power lines on two sides of us only about 20 ft from the antenna and or feed line. I think a noob is a newbie, ie a NEW person to the forum.
K
K
krystallo- Member
Re: VLF ant
Noob, OK, I'm not. Re your 13.8 Kv ant, What's the S/N ratio? OT
oldtimer- Member
Re: VLF ant
If you build a vert coiled ant at 90 deg from the pwr lines it may improve reception. OT
oldtimer- Member
Re: VLF ant
Hey OT. I'm pretty much saturated with noise here. I more or less live with it.
It is sometimes better and sometimes worse. There are a few things I could try but I haven't done them. I have only so much time mess with this and a lot of that time is spent building. One of the problems is that AM band has been mixed or fairly poor ALL winter.Decent signals will usually be ABOVE the noise (on a good day). The winter of '06 to '07 was much better (go figure, we went BACKWARDS in the solar cycle THIS winter ).
I tried running the Icom off batteries and got a LITTLE relief. I could mess with magnetic or other isolation balun type schemes. I also have a phaser but building a good second "noise" antenna would be hard. I'm kind of stuck with the single longwire I have. K
krystallo- Member
Re: VLF ant
Sounds tuff. You could always move to a more rural area. I'm in the center of Denver but the prw lines are in the alley. Also, my house is 1 blk from a very large city park. Lots of trees no major pwr lines. Very old residential. My long wire will be al least 45 deg from the lines. 2 parts, semi - balanced. So unless you are wired into this address, move out! OT
oldtimer- Member
Re: VLF ant
Hey OT.
No moving out possible, I'm pretty much "stuck" there for a number of reasons. I'll deal with it when I can as I can. I also go out on DXpeditions to the beach or forest and always get clean signals there.
K
K
krystallo- Member
Re: VLF ant
If there's a SAQ xmission this summer I might head to the eastern plains to pick it up. I'll have to camp out on a farmer's or rancher's land to do so to be away from noise. Grimeton Radio likes to rcv reports. Being at mile high it may be a good location. OT
oldtimer- Member
Re: VLF ant
Hey OT.I'm thinking about a Palomar upconverter for VLf to HF for (hopefully) better copy of future SAQ' transmisssions. K
krystallo- Member
VLF
Hey, krystallo. Good deal. What sort of antenns(s) will you be using? Since I'm on the mailing list for Grimeton I suppose I'll rcv notice abt next b'cast.OT
oldtimer- Member
Page 1 of 2 • 1, 2
Page 1 of 2
