Don't over-look the simple stuff
Post by Dr. Radio on Tue Oct 09, 2012 9:48 pm
Have a "dead" transistor radio (no sound)?? Before you get too crazy pouring over schematics and disassembling everything to make voltage checks--check this first--does the radio have a earphone jack????
Many times dirt and corrosion upset the tiny make/break contacts inside the earphone jack. This prevents audio from reaching the speaker. Carefully use some plastic-safe electronic cleaner and work the contacts back and forth with a earphone connector. You may even have to scrape the contacts with a sewing needle to get some conductivity back.
Just a hint.
Re: Don't over-look the simple stuff
Post by Doug Burskey on Wed Oct 10, 2012 10:08 am
I have had that happen on a Toshiba.
Doug Burskey
Number of posts : 226
Post by Guest on Wed Oct 10, 2012 10:19 am
I have found this to be the case on several radios and is one of the first things to check right after the battery.
Post by Guest on Wed Oct 10, 2012 10:47 pm
I've put a post up about jack maintenance on the tips forum also.
Post by Ken g on Thu Dec 27, 2012 12:15 am
Back in the 70's i used to buy hundreds of transistor radios through thrift shops and flea markets to fix resell & collect . Many of the pocket radios , they put the earphone jack right next to the battery . If that arm on the jack was installed up it was pretty easy for heavy handed people to push the battery against it in a rush to get the battery replaced and slightly bend that arm down disabling the speaker .
Many radios i fixed in the back seat on the way home ( i was a wee lad )
Ken g
Number of posts : 223
