Solved****Crosley 515, no sound
Page 3 of 3 Previous  1, 2, 3
Re: Solved****Crosley 515, no sound
Post by Ben Delk on Sat Oct 13, 2012 4:59 pm
Ok guys...here's the skinny. When you make a mistake, own it, share it and learn from it. The Crosley is working. In the attached picutures, sheet # 1 is crude drawing of the mistake. The picture shows how the old double tap cap was installed and how I had the new single caps installed. This radio has 5 double tap non-electrolytic caps. I did the same thing on all of them. I have installed double caps in this manner on several occasions and they always worked. Wired correctly or dumb luck....not sure. The drawing #2 shows how the old caps were original connected and how the new connect. I'm still trying to understand the 2 new caps connecting together on the feed side, then going to chassis. The 3rd picture is the finshed product bottow side. I thank everyone who has helped, tried to help, offer to help or made suggestions to help. I'll post a finished picture of the radio when I get it mounted in the case. So for now.....THIS BEAST IS DONE!!!!!!!!!!!
http://www.servimg.com/image_preview.php?i=58&u=17421296
http://www.servimg.com/image_preview.php?i=59&u=17421296
http://www.servimg.com/image_preview.php?i=60&u=17421296
Ben Delk
Number of posts : 443
Post by Bill Cahill on Sat Oct 13, 2012 7:01 pm
Congrats........
Number of posts : 4594
Post by Resistance is Futile on Sat Oct 13, 2012 10:52 pm
Perseverance pays off, Learned something else myself. Good Job.
Number of posts : 976
Post by Wildcat445 on Sun Oct 14, 2012 2:34 am
Good job. Glad you have it going
Post by Tony V on Sun Oct 14, 2012 2:23 pm
Glad to hear you got it playing
Number of posts : 663
Post by Guest on Tue Oct 16, 2012 6:33 pm
This has been a good thread. Glad you finally resolved the problem!
Post by Ben Delk on Tue Oct 16, 2012 10:15 pm
Thanks guys....no one happier to be finshed with the chassis than I.
Ben Delk
Post by Ben Delk on Sat Oct 20, 2012 3:36 pm
Here's the finished product, Crosley 515. The front finish is a walnut and mohagany mixed water base stain. The sides are water down medium brown. The whole case has a light spray of Moahawk prefect brown lacquer, then 5 coats of spray on gloss lacquer.
http://www.servimg.com/image_preview.php?i=66&u=17421296
http://www.servimg.com/image_preview.php?i=67&u=17421296
http://www.servimg.com/image_preview.php?i=68&u=17421296
http://www.servimg.com/image_preview.php?i=69&u=17421296
Ben Delk
Post by Guest on Sat Oct 20, 2012 3:47 pm
If it performs as nice as it looks, it will have been worth the trouble!
Post by Ben Delk on Sat Oct 20, 2012 5:40 pm
Thanks......For 4 1/2 inch speaker it is not too bad. I think the speaker in a bit overdriven. Sound pretty good up to about 60 % volume then the speaker has little rattle of a in it. Considering all it and I have been thru with this restoration, I'll leave it as is for now. I still think it is posessed. Ha!
Ben Delk
