double volume control
I have a 1934 majestic model 50 and It has, from what I can tell a double volume control and it is made of carbon and I believe it is cracked. One part of the schematics shows the volume control as 645 ohms and another part of the schematics shows part of the volume control right off the antenna at 10,000 ohms. There are more than three wires coming off the control. Under each of the volume controls in the schematics it says 1/2 of volume control. Do I need the part connecting to the antenna or can I just use another volume control at 645 ohms
chaz- Noob
- Number of posts: 9
Registration date: 2008-03-30
Re: double volume control
This would be an odd control and you may need to find a junker model 50 to obtain this part.
Johnnysan- Noob
- Number of posts: 8
Registration date: 2009-01-02
Chaz: what you have there is a TRF radio. That second part of the control is actually a RF gain control.
As the volume was turned up so was the RF gain in the antenna circuit.
I am also trying to find such a control Mine has 1500 ohms in the RF gain section and 11500 ohms for the volume side.
From a 1930 Phonola/Grimms TRF set.
Try this site, I have good luck finding older controls from Gary. Please read instructions carefully. He likely has what you need but it may take you awhile to find it.
Is that a model 50 Majestic USA made or is it a Rogers/Majestic model 50 Canadian made?
Similar topics» First Mod, fix the low volume bug through the C Peel in ios5
» The declining quality control of the LEGO product
» Looking For PAS2 "Large" Volume Control/Selector Knobs (Brown w/ Gold Middle)
» Volume control
» [A-3744] Alsamixer: Command Line Volume Control for Linux
» Volume control
