Philco 38-7 console
Philco 38-7 console
Post by Ben Delk on Tue Jun 19, 2012 3:57 pm
Saw a Philco 38-7 console on Craigs List a few weeks ago for $40, everything is there. The cabinet needs a light sanding and clear coat. I said "What the heck I don't have one", so I brought it home. It will be my next project and I'm wondering if anyone has one of these or restored one. Any "gottcha's"? It definitely has an odd tuner control, kinda' like an Etch-a-skectch on steroids. If you have any comments or gudiance on this model, send it my way.
http://www.radioatticarchives.com/radio.htm?radio=1981
Thanks,
Ben
Ben Delk
Number of posts : 443
Re: Philco 38-7 console
Post by Motorola man on Tue Jun 19, 2012 5:23 pm
Philcos used rubber insulated wire which is almost always dry rotted. If they are not already rotted, they will be in the future. So while you're replacing the capacitors & out of spec resistors, go ahead and either replace the wires or cover them with heat shrink.
Dave
Motorola man
Number of posts : 375
Post by Ben Delk on Tue Jun 19, 2012 5:32 pm
Excellent advice. Thanks
Ben Delk
Post by Bill Cahill on Tue Jun 19, 2012 9:45 pm
Most, if not all Philco capacitors are in bakelite blocks with tar filling.
With a little work, following schematic, and, parts list, you can figure out what is in them, carfully remove tar, gutt them, clean them, and, install new caps.
Alot of work, but, saves alot of mess trying to do it other ways...
I even gutted my dead shorted electrolytic in the set I'm working on now....
Number of posts : 4561
Post by Ben Delk on Wed Jun 20, 2012 8:34 am
I have replaced the caps in the bakelite blocks a few times and that is a bit messy but not nearly as messy as cleaning out the electr cans. I cut them open with a drimel, heat them with a propane torch then fill them with naptha and the tar washes out easily. I prefer putting the elect caps back in the cans, just makes a better looking and less crowded job. Started on the chassis last night. Tested the tubes, right off I could see the power and rectf tubes were blown. New tube on order today.
Ben Delk
Post by jerryhawthorne on Sun Oct 14, 2012 5:57 pm
I agree with Ben, on the electrolytics, I use a dremel with a cut off wheel and remove the base. The insides will pull out nicely. For the bakelite blocks, the are really simple and not messy to deal with, I just did 8 of them on my Philco 111. Take a heat gun on high and spend less than a minute heating around them while they are still mounted. With the cotton wire, no problems. If you have the rubber, well probably needs replacing any how.
I start prior to heating with a drill that matches the inside diameter of the grommets the wires come up through. With my hand drill, a half a turn and you can feel the wire breaking off.
Heat around the block with a heat gun and test after maybe 30 seconds of heat by pushing through the hole with an open large paper clip or any thing stiff of about that size. When the temp of the block is hot enough and you push, you will see and feel the block head down to the chassis. Take out the block with the attaching screw and watch where the star washer falls, it depends on what angle the chassis is setting. They are darn hard to find. Don't ask me how I know.
Pull out the whole tar and caps block. If you have heated it properly, it will come out in one chunk. Put in the cap, caps or cap resistor combo. Turn it back over and bend the wires over to hold parts in place. Mount it in place and remember the star washer for a good ground. Solder the wires and your done. I can do one in 5 minutes and never remove any wires.
Good luck and you will have a nice radio.
Number of posts : 734
Post by jerryhawthorne on Sun Oct 14, 2012 6:01 pm
duplicate, sorry.
Last edited by jerryhawthorne on Sun Oct 14, 2012 6:06 pm; edited 1 time in total (Reason for editing : duplicate)
Post by fixinmyphono on Fri Nov 23, 2012 2:40 pm
I have one. How is yours comming along?
fixinmyphono
Number of posts : 204
Post by Ben Delk on Fri Nov 23, 2012 8:21 pm
Mine has been finished so quite some time now but I failed to take completred picture of the inside of chassis. Maybe next time. Here's the finisehed outside. Note the cloth. I think it goes very well.
http://www.servimg.com/image_preview.php?i=88&u=17421296
Ben Delk
Post by fixinmyphono on Fri Nov 23, 2012 8:52 pm
Wow looks great!!!!
fixinmyphono
Post by Dr. Radio on Fri Nov 23, 2012 10:08 pm
Here's my take on the bakelite block issue...
I didn't want to mess with 'em. I mounted terminal strips and used the original screw hold-downs, only I used spacers so the threads of the screw only protruded as much as the original even tho there were no blocks in place. The individual components were mounted to my new strips for easy servicing and from above the chassis, no one can tell!
http://prepostmodern.com/philco80/philco80.html
Post by Ben Delk on Sat Nov 24, 2012 9:35 am
Very nice and quite creative.
Ben Delk
