EICO Model 320 Signal Generator
Post by Steve Myers on Tue Jun 12, 2012 3:38 pm
Hello all, I got a rusted EICO Sinal Generator Model 320 and re-caped it. Does anyone have the Construction Docs? I have found the Instruction Docs but I have a problem that it will not work. I have gone over it with my mentor and he has found that there are two lugs inside that have no wiring on them, and never has had. The two (old style) screw on fittings for the test probes have the "hot" lead but no ground. The two plugs are mounted with a fiber washer (to keep them off of the metal box that is the test equipment) but the Schmatic shows them grounded. There is also a solder lug mounted with the screw on conecters. If these two points were to be grounded, why the additonal expence of mounting them with the isolation fiber washer and grounding lug? Just mount them on the metal box and be done with it! I am trying to learn and get some old test equipment to work on radios. I am hitting a wall here and that is why the cry for help.
Thanks
Steve
Steve Myers
Number of posts : 16
Registration date : 2012-06-12
Re: EICO Model 320 Signal Generator
Post by Bill Cahill on Tue Jun 12, 2012 7:26 pm
Try this.....
http://www.ebay.com/sch/i.html?_nkw=eico%20manual&clk_rvr_id=353063636623&adpos=1t1&MT_ID=70&crlp=10620962204_2416792&tt_encode=raw&keyword=eico+manual&geo_id=9932&adgroup_id=3213568964
Number of posts : 4559
Post by Steve Myers on Tue Jun 12, 2012 10:16 pm
Bill, Thanks for the info, but that info on the 320 is the Instruction Manual. I need/looking for the Construction manual as I have the 320-K (K for kit) that was put together by a person who (I think) tried to use it. The info that you sent me to, I already have. Thanks again.
Steve
Steve Myers
Post by Bill Cahill on Tue Jun 12, 2012 10:42 pm
http://www.nostalgickitscentral.com/eico/eico.html
Try this. It's the schematic. Nice, and, large. Shows that jack grounded. I suspect it's been wired incorrectly.
Post by Steve Myers on Tue Jun 12, 2012 11:14 pm
Bill, Thanks, I have that already. I will wire the two Jacks/plugs but why did they isolate the two jacks from ground (insolated washers) and then put wire lugs to ground them?
Thanks
Steve
Steve Myers
Post by Bill Cahill on Tue Jun 12, 2012 11:22 pm
I don't know. But, I'd check all the wirring, if I were you.
