Philco 42-350
Philco 42-350
Came across a Philco 42-350 for $20 last week so I said "what the heck? Recapped and replace some rotten bushings and now it play A.M. very well but I cannot get FM. I was reading an article about the radio stating
the FM station were assign by the FCC but not license while this radio was in production. Humor me here but before I start digging around trying to find a solution, does this radio play FM stations?
Ben Delk- Member
- Number of posts: 35
Registration date: 2012-04-03
Re: Philco 42-350
What aree the frequencies on the fm dial? If it's the old fm band, it's no longer used. Sounds like it might be.
Re: Philco 42-350
BC 42 to 50 mhz. It would appear the FM is nonexistent in the year model 42-350. FM stations became obsolete by the end of WWII.
What about SW...SW covers 9 to 15 Mhz, with high sensitivity. Is it picked up on a standard areial?
Ben Delk- Member
Re: Philco 42-350
That was the old FM band. It stopped being used after 1960, I believe.
Some SW bands are no longer used, but, most are. I get alot of sw on my GE J-805 at night.
Re: Philco 42-350
I was able get several SW stations late last night, seems they were are Latino. Since you are on a roll here.....Must of the AM stations I receive are loud and clear but a couple even though they are loud and clear they chirp. Is this must like internal(electricalcomponent) or external (electrical interference, feeback, lighting, etc...)
Ben Delk- Member
Re: Philco 42-350
Lightnning would be loud, drowning out static, varying with pitch, and, frequency, depending on how manny strikes, and, how near.
Chirping, if you mean a squeling that goes in oscilation, sounds like it may be your radio oscilator.
Could mean your radio needs a better alignment.
Placement of certain componnents, especially in the oscilator cicuits can be crittical.
Also, certain things, appliances, etc., can cause interference. Coputers running, even in the same room can rais a havic with am radio, as can television.
The modern cfl light bulbs create their own noise, as do florescent lights.
I have even seen two radios playing in the same room where when one is tuned near the same frequency as the other, will cause harmonic noises, and, make at least one of the radios get a loud squeel.
Hope this helps some.
Re: Philco 42-350
No lightNing involved just lighting. I do have lots of elecrical in the area and a laptop with wireless within 2 feet of the radio, I'll try removing it. The sound is not like an ac hum or sequlc or squeel. It sounds like a baby bird chirpping. Oddest thing.
Ben Delk- Member
Re: Philco 42-350
Zenith and a few others made sets after ww2 with both FM bands on them.Is that old FM band used for anything today?
Doug Burskey- Member
- Number of posts: 21
Registration date: 2011-06-22
Re: Philco 42-350
All the documentation I can find states the pre and post WWII FM stations were unlicensed by the FCC and when the FCC got around to licensing FM the FM station were in a different frequency range so the old one no longer exist.
Ben Delk- Member
Similar topics» Picked up a Philco 89A for $20, Ebay. Has a BAD Veneer problem
» Replacement Cartridge for Philco 47-1227
» PHILCO 49-906
» New Reproduction Philco Cabinets Available
» Philco 650 Chassis Parts F/S
» PHILCO 49-906
