SOLVED Volume and power switch for an RCA T-64 help
Post by fixinmyphono on Sun May 06, 2012 4:04 pm
I have two t-64's the good one im fixing has a scratchy volume control onit so i put the one from the other in it it was sligly different but when i hooked up the leads to where i thought they should go the volume is all the way up when i first click it on and as i turn it away from the off position it grows lower. What did I do wrong and how should i fix it?
Last edited by Resistance is Futile on Fri May 11, 2012 11:58 pm; edited 1 time in total (Reason for editing : Solved problem noted)
fixinmyphono
Number of posts : 204
Re: SOLVED Volume and power switch for an RCA T-64 help
Post by Bill Cahill on Sun May 06, 2012 8:07 pm
Go back to original control, and, get some prper control cleanner, and, use it. That will solve the entire problem.
Deoxit, might help. I use a cleanner from Radio Shack.
Don't use cleanners that clean out carbon.
Number of posts : 4559
Post by fixinmyphono on Sun May 06, 2012 8:08 pm
ok will do thanks Bill
fixinmyphono
Post by sprman on Mon May 07, 2012 8:38 am
Hi sounds like you may have put the leads on backwards.Check how its wired.Easy to fix.Sprman
sprman
Number of posts : 365
Post by fixinmyphono on Tue May 08, 2012 11:08 pm
The leads were backwards, but i took the original and took it apart cleaned it and put it back it works great now!
fixinmyphono
Post by Bill Cahill on Wed May 09, 2012 2:21 pm
Congrats...
Post by sprman on Fri May 11, 2012 10:01 pm
Thats great! Sprman : )
sprman
