Airline Rudolph 05gcb-1540
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
I have recapped the electrolytics in this radio. At first I had no audio, then I jumpered it to another radios speaker/transformer, then I got a low hum. It has a resistor looking part that I think is a cap. Should I change it out? The tubes are hard to get to to check voltages. The transformer did show like 1.875k on the input and almost zero on the output, tested still in radio. Thanks
Rickey- Member
- Number of posts: 36
Registration date: 2011-09-06
Re: Airline Rudolph 05gcb-1540
Here is a better view of the big "resistor"!
Rickey- Member
Thats a resistor 47 ohm 2 watt
http://sparks-radio-shack.forumotion.com/t144-rudolph-airline-05gcb-1540
Resistance is Futile- Admin
- Number of posts: 627
Thanks RIF, it's a whopper!
Rickey- Member
I put another transformer on it and replaced all the other caps. I think the one that got the audio tranny was the mica mold! It's singing like a bird now! I mean a reindeer!
Thanks, I truly love the forum!
Rickey- Member
Here it is recapped
Rickey- Member
Here are the bad guys!
Rickey- Member
Congradulations on a job well done!
You need to replace all bad caps before you even attempt to fire up a radio. Alot of radios also used rubber wiring, which is also often bad. Another reason to restore before plugging in.
I doubt the mica mold cap took the transformer, though.
Alot of the cheaper transformers tended to go bad on their own.
Thanks Bill, more to follow!
Rickey- Member
After a couple of days I get distortion on this set.Now i have some voltages. The cathode on the 50c5 reads 5 volts dc. The cathode resistor reads 190, a little out of the 20 percent range, should be 150. I get low positive voltage on the grid pin ,1.2 volts. I should be on dc, correct? The radio improves vastly when i check the voltage on the cathode!
Rickey
Rickey
Rickey- Member
the resistors are beyond 20 percent in a couple of cases(30) percent.
Resistor 3 should be a 10 meg and it reads 17 meg! its on the 12at6 on pins 1 and 2, grid and cathode. I ordered a few resistors from mouser, but i dont think i ordered the 10 meg.Would this resistor cause distortion?
Thanks,Rickey
Thanks,Rickey
Rickey- Member
I don't know what you mean by distortion, but, it would cause issues with sensitivity.
The radio sounds like a bad filter capacitor, but they are ok!
Rickey
Rickey
Rickey- Member
Also, on pin 2 of 50C5 you should get low negative, or 0 volts. That's usually a bad coupling cap from plate of pre amp to 50C5. Replacement is mandetory.
Don't leave any original paper caps in it.
All caps were changed to begin with. I get very low positive volts on pin 2. The audio tube gets hotter than a 2 dollar pistol! The dial light glows very dim also?
Thanks
Thanks
Rickey- Member
Page 1 of 2 • 1, 2
Similar topics» Airline Rudolph 05gcb-1540
» Rudolph Reindeer cartoon card for Christmas
» Airline Abbreviations
» Airline Jokes
» Emirates Will Not Enter Airline Alliances
» Airline Jokes
Page 1 of 2
