GE Wildcat Issue
GE Wildcat Issue
I have a GE Wildcat, it has a problem with the left channel. If I move the balance all the way to the left the chassis becomes "amplified" ie. if I tap on the chassis it is amplified through the speakers. If I move the balance all the way to the right, the chassis is not amplified and I can tap on it without hearing it amplified through the speakers. Do you guys know what might cause this? Thanks!
PhonoBrit- Member
- Number of posts: 27
Registration date: 2011-09-28
Re: GE Wildcat Issue
The condition is called microphonics. Check for loose connections / broken solder joints, could also be a bad capacitor. Use a nonconductive probe (wood, plastic or ceramic) and lightly tap on each component. Usually the closer you get to the offender, the louder the noise.
Motorola man- Senior Member
- Number of posts: 117
Registration date: 2010-02-06
One of the smaller capacitors seems to be a little louder when I tap near it. Would that most likely be the culprit?
PhonoBrit- Member
Very possible. You can try heating up the solder joints on & near that cap. If that doesn't take care of it, then I would go ahead & replace it.
Dave
Dave
That did the trick, re heated all the capacitor joints and it magically went away! Thanks so much!
PhonoBrit- Member
Similar topics» New issue A4s
» ISSUE OF BONUS SHARES
» GE Wildcat Issue
» Game Informer's 200th Issue
» Podocarpus nivalis Issue
» GE Wildcat Issue
