Silvertone Model 7134
Post by fixinmyphono on Wed Oct 05, 2011 8:56 pm
Just picked this up on e-bay Does anyone have or can come up with schematics for it? Thanks Doug Pics below
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Registration date: 2011-09-13
Re: Silvertone Model 7134
Post by Motorola man on Wed Oct 05, 2011 9:19 pm
http://www.nostalgiaair.org/PagesByModel/696/M0017696.pdf
Looks like this one will need a bit more work than the Webcor. Is the front photofinish or veneer?
Motorola man
Senior Member
Senior Member
Number of posts: 117
Registration date: 2010-02-06
Post by fixinmyphono on Wed Oct 05, 2011 9:21 pm
I think its veneer but im a woodworker from way back so Im hopen to fix that part of the radio pretty good thanks Doug
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by Bill Cahill on Thu Oct 06, 2011 10:19 am
I definately see some photofinnish on bottom grainning.
Number of posts: 859
http://billcahill.webs.com/
Post by fixinmyphono on Sat Oct 08, 2011 12:59 pm
Radio came today looks like a nice project It has a list on the bottom of the cabinet with all the caps and resistors and such on it. Should help alot.But some of the resistors say something like .0001 mica, .00005 mica, .00025 mica how many volts are they supposted to be doesnt say? the others are like .05 400 volts or .05 200 volts Which I understand but some say .005,.01, 400 volts on one line does that mean in series or parallel? Also the resistors look nothing like Ive seen before not sure how to identify them. Not sure what the light brown waxy looking thing is at the top center of the page is that has stuff soldered to it.Speaker may be shot..Should I just replace all the caps you think leave the rest alone? Pics attached---Thanks Doug
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by Motorola man on Sat Oct 08, 2011 2:51 pm
The mica caps are the flat brown rectanglular parts. They have colored dots that signify the value. Stick with 400+ volt caps & you should be fine. Here's a page that describes the color code.
http://www.vcomp.co.uk/components/cap_codes/cap_codes.htm
The resistors are dogbone style. The color of the body & painted dots will give you the value. You've got several high value resistors which will probably need to be replace as they tend to change values over time. Here's a color code for them.
http://www.nostalgiaair.org/References/rmacodes/reschart.htm
The brown waxy thing is a coil. Don't replace it unless it's bad. The speaker cone can be patched using tea bags and flexible fabric glue.
Hope this helps.
Dave
Motorola man
Senior Member
Senior Member
Post by fixinmyphono on Sat Oct 08, 2011 3:21 pm
Cool thanks for helping I learn more each time and enjoy this alot! Im still not sure about though some say .005,.01, 400 volts on one line does that mean in series or parallel
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by Motorola man on Sat Oct 08, 2011 4:44 pm
Is it a dual section capacitor? Could you post a picture?
Motorola man
Senior Member
Senior Member
Post by fixinmyphono on Sat Oct 08, 2011 9:10 pm
Not sure what im looking for on that to take a picture of.
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by Resistance is Futile on Sat Oct 08, 2011 9:19 pm
take a picture of the capacitor .005,.01, 400 v with the printing showing. That may be the biggest capacitor with the three leads. It looks like it may be a two section electrolytic on the bottom of the picture hanging over the chassis with the red-black-grey wires. If I am right then that is the one to photo the printing.
The question you asked if its parallel or in series, would be one lead is common to both caps, the others are not in parallel because they should have a coil or resistor connected between two of the capacitor leads, they are not suppose to be connected with both leads together. (If they were then it would be a parallel circuit.)
Number of posts: 627
Post by fixinmyphono on Sat Oct 15, 2011 12:07 pm
The big one is a 50-30-20 mfd electro at 150 volts
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Sat Oct 15, 2011 12:31 pm
Sent away for some caps and resistors.Ordered some rubber feet and some tuner cable, new bulb, tension spring,grill cloth for both the radio and the webcor phono project.
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Tue Oct 18, 2011 8:09 pm
Repaired the speaker some tonight need some felt for the center I guess and black magic marker to color the coffee filter patches.Replaced the power cord with a new one was tempting to plug it in but wont until new caps and resistors are put in.Dial cord is on the way not sure how it goes on it yet but I guess Ill figure it out in time...Doug
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Thu Oct 20, 2011 8:23 pm
Replaced the old broken dial cord tonight got it working fine found a similar diagram online. Rubber feet came and new grill cloth along with the new bulb for the radio.Hope the caps and resistors come before the weekend gets here. Exclamation
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Thu Oct 20, 2011 8:29 pm
Found the dial string guide here.
http://www.theoldradiofixerupperguy.com/dial%20cord.html
Mine was number 31
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
