webcor model 1138-1 Concerto
Page 2 of 2 Previous  1, 2
Re: webcor model 1138-1 Concerto
Post by fixinmyphono on Mon Oct 10, 2011 5:08 pm
the paper cap isnt an electro?Could I use a 47 uf at 250 volt electro cap?Or a .47 630 volt paper cap?
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Registration date: 2011-09-13
caps
Post by fixinmyphono on Mon Oct 10, 2011 5:09 pm
willy3486 wrote:There is a good article on the color codes of caps and resistors at
http://www.vcomp.co.uk/components/components.htm
I printed it off to have on my workbench. I can do the resistors but I forget how to do the caps.
Cool ty site saved!
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by Resistance is Futile on Mon Oct 10, 2011 5:14 pm
Somthings wrong here, looking at SAMS FOLDER the diagram of tube and components everything is on the tube side of the board, is this all handwired? Or printed circuit? On the actual phonograph?
Number of posts: 627
Post by fixinmyphono on Mon Oct 10, 2011 5:17 pm
Resistance is Futile wrote:Somthings wrong here, looking at SAMS FOLDER the diagram of tube and components everything is on the tube side of the board, is this all handwired? Or printed circuit? On the actual phonograph?
Hand wired but its supposed to be right and it seems to match up for the most part
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Tue Oct 11, 2011 7:56 pm
Put new wires in the tone arm tonight.
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Tue Oct 11, 2011 8:04 pm
Making a new rubber bumper to go on the velocity trip using a piece of wire casing with a piece of heat shrink tubing on the outside of it to get the right diameter.
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Tue Oct 11, 2011 8:10 pm
The actuating pawls tip is worn off, wont catch the velocity trip anymore I need to take it out and grind the tip to make a new edge once more.
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Tue Oct 11, 2011 9:26 pm
Just found the part im looking for to fix this at the voice of music .com how cool is that!!!
http://www.thevoiceofmusic.com/catalog/part_detail.asp?PNumberBase=1413
fixinmyphono wrote:Making a new rubber bumper to go on the velocity trip using a piece of wire casing with a piece of heat shrink tubing on the outside of it to get the right diameter.
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Thu Oct 13, 2011 8:38 pm
Worked on the actuating pawls tip hopefully it will work re-assembly has begun. Doug
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Post by fixinmyphono on Sat Oct 15, 2011 1:14 pm
Ordered the caps and resistors.Ordered the rubber bumper for the velocity trip, rubber feet for the base,some wire to replace some exposed wires,So when it comes Ill be a busy bee for sure....
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
