Admiral 5RP4 Record Player issues
Page 2 of 2 Previous  1, 2
Re: Admiral 5RP4 Record Player issues
Post by PhonoBrit on Mon Oct 24, 2011 6:45 pm
Bill, why would I change the spring's location from it's stock factory position?
PhonoBrit
Number of posts: 27
Registration date: 2011-09-28
Post by Bill Cahill on Mon Oct 24, 2011 6:49 pm
Because it looks like it isn't in it. Have you got the repair mannual on it?
Are you sure you re-installed motor properly after replacing grommets? Did you replace motor grommets? If not, motor may be sagging??
Number of posts: 859
http://billcahill.webs.com/
Post by PhonoBrit on Mon Oct 24, 2011 6:53 pm
I replaced the grommets with silicone rubber that I applied myself. I guess it's possible I didn't judge the correct distance when performing this job. Where would I locate such grommets?
PhonoBrit
Number of posts: 27
Post by fixinmyphono on Mon Oct 24, 2011 7:11 pm
Try here http://www.thevoiceofmusic.com/catalog/phono_motor_mounts.asp
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
Registration date: 2011-09-13
Post by Bill Cahill on Mon Oct 24, 2011 7:19 pm
There's your problem. You did the job wrong.
You need to go to Gary Stork at VM enthusiasts, and, buy the correct grommets.
Post by PhonoBrit on Mon Oct 24, 2011 7:59 pm
Thanks Bill, I hope they do the trick!
PhonoBrit
Number of posts: 27
Post by Bill Cahill on Tue Oct 25, 2011 12:41 am
I hope they do the trick. Gary said this is the first call for the Admiral grommets, and, he's excited.....
I'm buying an Admiral 45 rpm adaptor to finnish my table model bakelite radio, phono.
Post by Resistance is Futile on Tue Oct 25, 2011 11:35 pm
Looking at your mechanism, you may have a bit of dirt or grit so it might also be under the moving plate(s) or a metal burr, or bent piece that would prevent total movement. Just an observation. Clean and re-oil!
Number of posts: 627
Post by PhonoBrit on Fri Nov 11, 2011 1:37 pm
New motor grommets did the trick! Thanks to everyone who helped!
PhonoBrit
Number of posts: 27
Post by fixinmyphono on Fri Nov 11, 2011 7:02 pm
cool glad it worked
fixinmyphono
Senior Member
Senior Member
Number of posts: 89
