Admiral 5RP4 Record Player issues
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
Greetings all. I have a mid 50's plastic cased Admiral 5RP4 record player. I have replaced the idler wheel and drive belt with new ones. However, I can only get 78 and 16 to work. On 33 and 45, the idler wheel doesn't appear to be making contact with the platter. Do you have any suggestions? Thanks!
PhonoBrit- Member
- Number of posts: 27
Registration date: 2011-09-28
Re: Admiral 5RP4 Record Player issues
Might need another belt for those spds., or, idler wheel is bad, or, mechanism is'nt working right. Got any pictures? It would help.
PhonoBrit- Member
Idler wheel is brand new, as is the drive belt.
PhonoBrit- Member
Any ideas on this one guys?
PhonoBrit- Member
See if the tension on the idler spring is good?
fixinmyphono- Senior Member
- Number of posts: 89
Registration date: 2011-09-13
Tension feels fairly strong.
PhonoBrit- Member
hmm when you cycle it to 45 or 33 can you pull on the spring to make it the idler wheel make contact enough to have it make it spin the right way?
Here is a video of the admiral idler wheel mechanism.
http://www.youtube.com/watch?v=J-gNQfgIbtc&NR=1
PhonoBrit- Member
Looks, and, sounds to me as if your wheels are bad. I think the lower tires have likely hardeenned, and, glazed over, plus, shrunk.
You need to replace the rubber tires.
I'd say contact Gary Stork.
I have a new idler wheel and belt on this machine. Gary actually suggested this place for help.
PhonoBrit- Member
But, it sounds like either your other two small wheels are bad, or, you should have 3 belts. Not sure which on this model.
The one I have is a 3 spd., so, that won't be alot of help in your case.
I looks like to me the tension spring is fastened in the wrong place as its pulling the idler away from the turrets instead of pulling it towards them.
Tony V- Senior Member
- Number of posts: 108
Registration date: 2008-09-13
I actually think an idler wheel with about an increase of 2mm in diameter would solve my problem. Any thoughts?
PhonoBrit- Member
How about putting the tension spring in a different spot?
It isn't that simple on wheels.. Just move the spring..
Page 1 of 2 • 1, 2
Similar topics» PSF VERSION 17 100% WORKING!!TRY IT NOW!!!!! Player Chams+No Recoil / No Spread+No Camera Shake+Unlimited Ammo+Player Box 2D
» Keesha Real Player Chat
» Notts Forest Record Breaker
» Patient Record: Adalhard Krüger
» Mod : Windows Media Player 12 Zune Style
Page 1 of 2
