Zenith J615 - Poor reception; Distorted sound
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
Hi All:
I'm an advanced beginner, if that makes sense, with a Zenith J615 Chassis 6J05. It was completely dead on arrival. I replaced all the electrolytics and paper caps. All tubes were checked and are good. The radio will now tune in a few stations, but weakly and with a fair amount of hum and static. The sound seems garbled or distorted as well. Any ideas which direction I should go from here?
(I actually bought three of these radios. The first one was a real mechanical mess, so I bought two more hoping I can get two good ones out of the three. The same issues described above relates to a second J615 I got working again. Maybe these particular radios weren't all that great to begin with in their day?)
Jack
Jack
Jack21- Noob
- Number of posts: 11
Registration date: 2011-08-30
Re: Zenith J615 - Poor reception; Distorted sound
Welcome to the forums.
May we see pictures? Do you have a schematic?
If this is a later set, including late 40's, they have issues with built in capacitors getting leakage in the I F's.
Also, Zenith tended to use alot of rubber wiring. Maybe that has gone south, and, is causing a short??
Sounds very possible.
You have sets playing. Now we need to help you locate, and, repair the problems.
Check resistors too, they can be out of tolorance.
Motorola man- Senior Member
- Number of posts: 117
Registration date: 2010-02-06
I do have the schematic and I think I posted a couple pictures, but I'm not sure where they went.
The wiring seems ok. I have a feeling it may be the IF cans. Are they interchangable or can they be dismantled in order to replace the capacitors?
Regarding the resisitors, is it reliable to check them without unsoldering them? It would seem that if I go to the trouble of unsoldering them, I may as well just replace them as they are so inexpensive.
Thanks!
[img][/img]
Thanks!
[img][/img]
Jack21- Noob
Your problem is you are typing in the beginning, and, end of img.
If you are using something like photobucket, Point your cursor to the photo you wish to copy. A list should pop up.
The last one is the image code.
Left click on it several times to completely highlight the code. Then, right click on that code, and, select Copy.
Go to your post you are posting here, and, right click on blank spot. Select Paste.
That puts in the entire image code.
When you are finnished posting, and, tell the forum to send it, your pictures will show up in the post.
It's actually very easy.
Hope this helps.
Hope this helps.
Here are a couple pics.
Can I just swap out these IF cans for two NOS? Schematic says they are both 22 ohm and Zenith Part #s 95-1101 and 95-1102 or Merit Part #s BC-352 and BC-355.
Jack21- Noob
Bill:
I followed your instructions and got the pics to appear. But they are Giant-sized! How would I attach a thumbnail?
Jack
Jack
Jack21- Noob
This size is fine. Thumbnail is too small.
Your radio has the infamous I F transformers with the built in mica caps in the base. They often get silver mica disease. The only cure is to dismantle, clean, and, put back together the bases of the I F transformers. Other than that, have you replaced the selinium rectifier?
Have you tested the tubes?
Bill:
I did check the tubes and replaced two. I did not replace the selinium rectifier, but will look at that (to be honest - I wasn't aware of such a thing).
Regarding the IF cans, I read another thread on "Silver Mica Disease". That member had the same problem on the same Zenith radio and he choose to dismantle and remove the silver mica caps, replacing them with external caps. I think I'd prefer to just replace the cans. I found a source that has the Zenith and the Merit cans referenced in the schematic's part list, but I would rather use a Miller can that doesn't have the silver mica caps.
Is choosing a substitute Miller can as simple as getting an input and an output Miller 455kc can with the same number of lugs or is there other criteria to match up? The source has a slew of Miller cans.
I imagine that replacing the cans will necessitate an alignment, but I have a signal generator and will need to learn how to do this procedure - so this is as good a time to do that as any.
Thanks,
Jack
Thanks,
Jack
Jack21- Noob
I checked my schematic, the chassis, and did a bit of research and have concluded that this Zenith model does not have a selenium rectifier. I believe that is accomplished with a 35W4 tube.
Jack
Jack
Jack21- Noob
O.K. on rect. No, you can't go by just any I F transformer, You have to use a noted correct replacement, including in the Miller line. Use the correct replacement for each transformer. You could also install outside mica caps on the I F transformers you have, as long as you put in the correct valuess.
Yes, it will need realignment.
If i install mica caps on the exisiting cans, I would remove the silver mica caps integrated inside - yes?
Jack21- Noob
That's correct.
I have ordered replacement IF cans, as per the specs. Meanwhile, I found a post by someone who took apart the existing IF cans and cleaned the silver mica caps. I tried that on both cans, found that there was definately silver mica disease, cleaned them up nicely and re-installed them.
The sound is improved with much less static. However the tuning sensitivity still isn't all that much better and the sound is still "garbled". Is it possible that I have a weak tube after all? I checked them all, albeit with an emmission tester - not a mutal conductance tester.
Thanks!
Thanks!
Jack21- Noob
First, emission testers aren't that good. Could still be a bad tube. Have you replaced all the paper caps?
Did you do all the I F transformer repairs? How manny are in this set?
If it's an am, fm, there are likely 4. If you only did two, you also need to do the other two.
Page 1 of 2 • 1, 2
Similar topics» Britains poor driving skills
» Mod of Sound Image 3.2 - Charisma and Attraction Subliminal For Men (v.2), need instructions on how to use the mp3
» Zenith J615 - Poor reception; Distorted sound
» Bad radio signal/reception
» Zenith Chassis 5K505 audio problems
Page 1 of 2
