first radio - suddenly quit working
Post by 3 chord on Mon Aug 01, 2011 10:49 pm
Hello, new guy here.
So I picked up a real nice, original (I think) bakelite radio today at a used furniture store. $24 which I think is a good deal, no cracks, back panel is there, all seems ok for the price. It is a Coranado 6B11 tabletop, around a 1947 I think. Real good shape, nice marbled brown bakelight with matching knobs. Looked and sounded great in the store. Big sound.
So I get it home and it is dead, tubes and dial light don't light up. No sound, nothing. Not sure what happened but maybe I shouldn't have been playing it in the store (new guy mistake!). Did the car ride shake something loose or is it just what happens to old radios that have been sitting?
I pulled the chassy and the caps look old, paper, waxy looking things. Black waxy stuff in lots of places.
So what do I do next, test tubes, replace caps, both. Is there an output transformer on these things?
Any help would be great.
3 chord
Number of posts: 7
Registration date: 2011-08-01
Re: first radio - suddenly quit working
Post by Bill Cahill on Tue Aug 02, 2011 12:24 am
First, the radio should be re capped, and, have electrolytics replaced. If any of these parts suddenly shorts, it will dammage, er, burn out tubes.
Then, test tubes.
Welcome to tube radio forums.
Number of posts: 859
http://billcahill.webs.com/
Post by willy3486 on Tue Aug 02, 2011 8:58 am
I do what Bill said. Replace the wax caps then test tubes. In about 95% of the time that solves the issue I have found out. Since it was working it sounds like there shouldn't be much wrong with it.
Senior Member
Senior Member
Number of posts: 72
Registration date: 2011-07-02
Post by 3 chord on Tue Aug 02, 2011 9:05 am
Thanks guys. I will start seeing what caps I need. Now when I think of caps I am thinking about the paper cylinderical ones, are there others too? I see Bill mentioned electrolytics. Not sure the difference.
Sorry for the dumb questions. Also should I replace the two prong power cord while I am at it?
3 chord
Number of posts: 7
Post by Bill Cahill on Tue Aug 02, 2011 10:14 am
Power cord replacement would depend on whether it is rotted, or, not. Condition is important to safety.
Electrolytics are the capacitors in the power supply that filter the dc voltages. They are crittical in the way you install them. The positive ends, must be connected where they belong. If you reverse these caps you will do great harm to the electrolytics, the radio, and, perhaps yourself.
I do mean the paper caps primarily on the capacitors to replace otherwise, as well.
Also, make sure through resistance checks that none of your resistors have gone substantially off value, usually no more than 20 percent off tolerance.
Caution, care, replace one part at a time, and, dressing are somewhat crittical. Also, if you have rubber wirring, and, it's rotted, that will need replacing, as well.
Post by 3 chord on Tue Aug 02, 2011 10:34 am
ok thanks, I think I can get started.
btw, although I know very little about tube radios (well i know very little period!), I have been using tube guitar amps for a long time so I will exercize the same caution when I am digging around in my radio.
I think this will be a fun project. There is just someting about glowing glass!
thanks again
Jarrett
3 chord
Number of posts: 7
Post by Bill Cahill on Tue Aug 02, 2011 10:44 am
Have you any electonics experience at all? If not, you need to learn things first. I wouldn't dive into it until I get some book, and, practical experience learning, plus, some basic needed safety, and, test equipment.
Post by 3 chord on Tue Aug 02, 2011 12:10 pm
Here are some pics of my radio. Looks like someone did a little mod. A pot of some sort was added to the power chord and to a pin on one of the larger tubes (power tube?). The non-original circuit also has a modern orange capacitor. Any idea what they were trying to achieve?
And I appologize if my photos are not great or the incorrect size but hopfully they demonstrate 1) the modification and 2) the radio I have.
thanks, Jarrett
[img][/img][img][/img][img][/img][img][/img][img][/img]
3 chord
Number of posts: 7
Post by Bill Cahill on Tue Aug 02, 2011 5:02 pm
Without a schematic, it's hard to see what was done. The orange capacitor is fine. It's a replacement line capacitor. Other caps need replacing, including the big electrolytic cap with colored wires. The black wire is the negative. That is the cap most crittical to correct connections.
The red is one of the positive connections.
I see part of the symptoms. There is a burned out power resistor, and, looks like there was a small fire. A cap that looks like a mica cap has been singed, may be dammaged.
This radio definately needs proper rebuilding.
Post by 3 chord on Tue Aug 02, 2011 10:36 pm
Any idea what the previous modification was. The radio has a potentiometer mounted on the back panel (it can be seen laying one the bench in the second picture). It was spliced into the main power cord and the other lead goes to thru the replaced orange cap and then terminates at a tube pin.
I will probably remove this mess once I get a schematic but I do wonder what purpose (or detriment) this served.
And good luck today (apart from the helpful advice here on the forum), I found a local guy with a good supply of caps, resistors and other things that I will need.
As far as a fire goes, I think if there was it was a while ago, nothing smells burt inside the cabinet, just the old tube amp musty smell I would expect. Since the radio worked yesterday (I know, I should not have tried it Embarassed ), if the fire was recent I would think I would have smelled something (as I had the chassis out yesterday too).
And thanks for your patience and help, it is most appreciated.
3 chord
Number of posts: 7
Post by Bill Cahill on Tue Aug 02, 2011 11:49 pm
What is the tube number that control is connected to, and, which pin of the tube? Sounds not right.
There is a burnt looking resistor, and, that may be what failed.
Something did fail for you, and, we need to find out what, and, why.....
Post by Resistance is Futile on Wed Aug 03, 2011 4:24 pm
Looks like the volume control was bypassed with another external unit. since only the power switch is wired up on the external switch, it says to me that is what was overloaded. You definitely need to do some parts replacing.
If the blackened parts are close to the original volume control, Do not power up the radio. Do a wire check to make sure you don't have further shorts. You may have a wiring error.
I also see a bare end on one of the power leads. This may have not been soldered as it look exposed. Its the copper colored one. they may have connected it to an existing wire, or part and just did a finger wrap rather than solder. Check it out. If thats the case it may have come free and therefore no power. Looks like a da-fingerpoken mechanics vorken. Crying or Very sad
Number of posts: 627
Post by 3 chord on Wed Aug 03, 2011 6:03 pm
I think when I change the caps and go thru this radio, I will just get rid of the modification circuit all together, all it consists of is one cap (the orange one) some wire that is spliced into the main power cord and the potentiometer.
When I did power the radio up, the main (original) on/off/volume pot worked so I am confused why someone would do this. But then again, anything could happed in +60years or so.
Too many folks think they can do better than just fixing what is wrong, sad, I see the same thing with botched mods on guitars and guitar amps Mad .
Oh, and to answer Bill's question, the power to the non-original circuit (pot) is to pin #2 on the 35Z5GT tube, the same pin the original power chord is wired to.
The more I read, the more I am starting to know what to look for (thanks to you guys around here!), the more I think I should have passed on this radio but I guess even if I over paid at $24, it will still be a good project. The case is in good shape and polishes up nice. I will stick with it and see how I do, hopefully for another $30 or so it will be up and running (I hope). Still cheap entertainment in today's world!
Any good leads on used 12SA7's, SK7's or SQ7's? Maybe the 35Z5 and the 35L6 too?? I will see what I need down the road.
Oh and more good news, found the schematic on-line yesterday, Free!! Looks like it is around a 1941 radio.
Jarrett
Last edited by 3 chord on Thu Aug 04, 2011 12:43 am; edited 1 time in total (Reason for editing : spelling)
3 chord
Number of posts: 7
Post by sprman on Sat Aug 06, 2011 12:39 pm
That looks like you got a mess on your hands.Take your time and be careful .Should not be to hard to fix it..Sprman : )
sprman
Wise Man
Wise Man
Number of posts: 258
Registration date: 2008-03-27
Post by Bill Cahill on Sat Aug 06, 2011 12:56 pm
3 chord wrote:I think when I change the caps and go thru this radio, I will just get rid of the modification circuit all together, all it consists of is one cap (the orange one) some wire that is spliced into the main power cord and the potentiometer.
Jarrett
Sounds like it's wired wrong.That's the hot side of the line. End of control should be going to B-.
