RCA Victor -A new dog in the family...... It's Alive!!!!!!!!!!!!!
Page 6 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Re: RCA Victor -A new dog in the family...... It's Alive!!!!!!!!!!!!!
Post by Bill Cahill on Sat Apr 20, 2013 11:43 am
You know, Ron, I think you're right. Looking at it more closely, I sse the herringbone, and, thoigh I do see a white line in the middle, I don't see fold over. Might be it just needs better adjustment, which I know it does. But, I don't want to do final adjustments until it's back in the cabinet, which won't be until I get more work done on that.
Next thing I will do is replace the detent, which is broken. Then, I have to adjust the fine tunning.
All this will give it more bench running time.
Bill Cahill Smile
Number of posts : 4594
Post by Bill Cahill on Sun Apr 21, 2013 1:46 am
Played set for 1.5 hours tonight. I did some adjustments on audio, and, agc . Set's showing a pretty good picture.
Post by Kamakiri on Sun Apr 21, 2013 8:58 am
Congratulations Bill! Looks great!
Kamakiri
Number of posts : 6
Registration date : 2012-08-24
Post by Bill Cahill on Sun Apr 21, 2013 7:59 pm
Ah, fug---ggg-e!
Set went backwards today. AGC problem made a come back.
Tried three different agc tubes, one stabilized it but, barely.
I now have twitching back in picture, and, I'm finding out that adjusting osc. screws in tuner is proving impossible, as they are frozen.
Post by Bill Cahill on Mon Apr 22, 2013 3:17 am
Well, my problems aren't over.
I adjusted the vertica., and, it's much better.
I tried adjusting some of the oscilator trimmers, and, have 2,3,4,and, 5 producing good sound, but, fine tunning isn't exactly centered. Further, I still have two problems.
First, I have very intermittent agc problems that are at their worst when the set is cold.
Secondly, a continued problem or the horizontal wanting to twitch.
I'm not happy with the way it's playing.
Post by Bill Cahill on Wed Apr 24, 2013 5:35 pm
Ran into a snag. I decided to go ahead, and, replace the detent in tuner. That turned into a big nightmare, and, the other parts weren't totally interchageable. My shafts are longer, and, the main front mounting plate is slightly smaller. I was able to use shaft assembly with ball bearings. However, I'm haveing a slight binding problem, and, I'm having other issues, and, worries.
This is gonna take awhile.
Post by Bill Cahill on Sun Apr 28, 2013 12:18 am
I have almost totally eliminated the binding problem. Cleanning contacts helped alot.
I found bag of loose parts to set, and, put two missing tube shields back on radio tubes. Found a few parts i lost, and, put them back with set, and, found, and, repaired correct channel selector knob.
Did some adjusting of yoke assembly, and, put good replacement picture tube bumpers on. Original were rotted.
Hope to be trying set soon.
Post by Bill Cahill on Wed May 01, 2013 11:46 pm
I just spent two hours tuning the radio. Both bands were way off frequency. Fm is slightly better, and, am is greatly improved.
May need to do tweaking when set's back together, but, it's alot better.
Post by 75X11 on Thu May 02, 2013 12:08 am
Very Happy
Post by Bill Cahill on Thu May 02, 2013 5:00 am
Well, more good news on the radio. Some adjustment screws on the tuner, and, FM det. transformer were out of alignment, and, frozen. I was able to free them up. FM is now working very well.
AM was also quite weak, and, I found the correct adjustment for that, plus Oscilator, and, got it in tune. I'm even getting a weak fm station that is nearly impossible to get here. It's not real loud, but, it IS coming in.
Other FM stations are great..............
So, I'm calling the radio finnished, except for the dial cord.
Bill Cahill Very Happy
Post by Bill Cahill on Sat May 04, 2013 9:11 am
Got tv playing, again, last night. Bad news....
It plays, but, sync is barely holding, reception has gotten worse, intermittent agc still acts up, and, along with weak sound, there is now a loud audio buzz.
Apparently, it's not fixed.
Post by Bill Cahill on Thu May 09, 2013 3:20 am
MOre bad news........ Sad
Decided to work on set tonight. I hooked everything back up. Decided to try radio first. AM works o.k. FM, NO. I get some buzzing at full line voltage, and, two weak tv stations, but, otherwise radio fm is totally DEAD!
You don't want to hear the words going through my head right now.
Just let it be known, I'm very, very dissappointed.
Post by 75X11 on Thu May 09, 2013 9:44 am
I know that unit is going to provide more than frustration before too long. Sorry about the setback.
Post by Bill Cahill on Thu May 09, 2013 10:43 am
Thanks. Got any ball peem hammers you can spare? I think it needs a charactor adjustment.
Post by 75X11 on Thu May 09, 2013 12:12 pm
Here's a guy who should be able to help get the job done,or at least give you a break from it for a few minutes! Very Happy
https://www.youtube.com/watch?v=U2fSw0ua5K0
Post by Bill Cahill on Thu May 09, 2013 2:29 pm
Thanks. I needed that. But, I already tried that technique.
Didn't work.
Post by Bill Cahill on Fri May 10, 2013 11:45 am
I've found the problem!
Last night I located a second copy of the sam's schematic, and, started looking at it.
When I first rebuilt the set I saw nothing in the oscilator sefction from under the chassis, and, there is a somewhat hard to remove shield above the chassis.
Last night something told me to look at one of the pictures of the chassis. I did, and, found a .01 paper capacitor.
It is a bypass capacitor on the plate of the oscilator tube to keep the rf out of the power supply.
That capacitor, of course, has failed.
It is used for the FM.
I will replace it. I removed the shield, and, there it is, all nasty, and, leaky.
Post by Ben Delk on Fri May 10, 2013 1:30 pm
Man this is lots of work for a black and white picture but then to each his own. Keep after after it Bill.
Ben Delk
Number of posts : 443
Post by 75X11 on Fri May 10, 2013 4:57 pm
It makes for great reading!
Post by Bill Cahill on Sat May 11, 2013 11:03 am
Well, replace cap last night. NO go. Same thing.
Tried different tubes. New 6J6 made fm slightly louder, but, no better. Other tubes didn't help. I had a terrible time removing 6AL5 from set, and, had to remove chassis, and, pry it out...
I tried a diffeent one, and, fm was totally dead.
This set is in big trouble!
I may give up on it, now.
Post by 75X11 on Sat May 11, 2013 11:33 am
Maybe this one needs to rest awhile. Sleep
Post by Bill Cahill on Tue May 14, 2013 5:23 am
Hope to get back on radio later today. I have an idea, or, two.
I'm not giving up. I like it too much.
Besides, after all I've done, why quit now??
Post by Bill Cahill on Wed May 15, 2013 12:01 am
Infamous last words. Now am is also dead.
I also have a new tv problem.
Phooey.
Post by 75X11 on Wed May 15, 2013 12:18 am
You are just doing these things to stay interesting, aren't you? Very Happy
Post by Bill Cahill on Wed May 15, 2013 5:14 am
NO, sadly I'm not. Yesterday was a bad day. The fm broke down first. Then, I dropped the chassis on the set while trying to pull the fm det. tube. That broke the first IF coil on tv. The, while trying to fix fm, am died.
I now have three major probllems.
A broken coil, a dead radio, and, broken radio dial cord.
