RCA Victor -A new dog in the family...... Now with pictures!
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
Am I nutz???
Just won this gem on e bay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&rt=nc&nma=true&item=200582690946&si=ODFBSX7469eKgogfC7Q4yCCW2gU%253D&viewitem=&sspagename=ADME%3AB%3AEOIBSA%3AUS%3A1123
I'll be picking it up in about a week.
Re: RCA Victor -A new dog in the family...... Now with pictures!
That was the beginning. I posted that last year in another forum.
Ouch....
Just picked up set today.....
It may be beyond repair.
Table. Veneered. Most internal veneer missing.
Missing chunks of outside veneer.
Legs wobbly.
TV No back. Veneer chips.
Very bad rust on entire chassis. Rust on hv cage, and, power transformer...
One tube missing, and, socket badly corroded.
I found what was left of the original ion rap. It fell apart, and, part of it turned to dust.
Set is filthy. One back control badly dammaged. Rust on front controls. Speaker has a hole in it. Grill cloth is toast....
Don't yet know condition of picture tube.
Finnish on outside of case is shot.
It was a beautiful walnut case used to be beautiful.
Legs wobbly.
Dismantled set tonight. Picture tube is a rebuilt. It checks good, except the needle won't go all the way to 0. Is that gas?
Even won't when I cut filament voltage.
Checks 700 on BK 667.
Excellent life test, good cutoff. Took 40 second to go near 0 on life.
Acqua dug is flaking off.
Front to middle of chassis is filthy, no rust.
Back is rusty.
Ion trap is toast.
Speaker, outside of one rip, is still good....
Tuner detent is broken....Fine tune belt is broken....
One radio knob is missing....
MY OPINION has changed. Now looks repairable.
I know one rear control is toast....
If I were to guess, a nice shorted cap killed that.
I think it may be salvageble.
Just not sure why pix tube is acting funny.
Back is rusty.
Ion trap is toast.
Problem solved. Didn't notice, but, meter movement was slightly off. Adjusted it, now tube checks great.
Looked at bottom of set today. Nothing trustworth, but, I see evidence that alot of work was done to keep it playing. This set is mostly filthy with dust, and, cigarette smoke.
It's gasping from nicotine...
I'll bring it back to life.
Looked at set today. The hv section has some rust. Not good. Worse, the resistor on back of chassis is solid rust, and, corosion!
Definately not good.
That seems to be the worst of the dammage. 12AU7 socket may also be toast.....
Tisk, tisk.
Found the original reason why they gave up on it....
The resistor bank on back of chassis had shorted out, and, explloded on both sides, and, middle. It is charred black, and, has a blow hole in the middle.
Can anyone help me find a good one?
There is some rust in hv secion, including on flyback, but, may not be serious......
I'm also missing the part of the raido that attatches to dial cord. It should hav e pin that fits into a matching socket on dial pointer on front of cabinet. Can anyone help me?
Also need a back cover for it, and, one of the radio knobs.
I'm going to repair the veneer with veneer from table, then, re veneer table.
I'll be repainting hv cage, and, power transformer....
Here are some pics of how set sits now........
As you can see, there are burn spots on the back of the resistor. I haven't checked it yet to confirm the dammage. Notice the rust in hv section, but, it isn't all that serious.
This set is filthy.
Back top of chassis is very rusty, and, 12AU7 wafer is all white with corosion, and, dry mold.
Don't know actual condition of anything, yet.
These are just early pictures.
This set is filthy.
I'm going to start looking for parts for this old gem. First, I'll check power transformer, and, finnish cleaning set. I also have to confirm resistor had blown.
There is at least one pot not working.
HV section needs major cleanning, as other sections do....
Picture tube is good, but, needs re coating.
I need to find two radio parts for it, and, a back cover. I have to re paint hv cage, and, top of power transformer.....
Wish me luck, guys.....
I'm a gonna do it. Slowly, but, I will do it....
I've found out all I need to find lut for now. There is a list of parts I need.
All 3 back controls. One was burned, and, fell apart inside.
One shorts while turning.
One checks o.k., but, is making a crunching sound.
Back mount resistor bank. Burned out.
Looks like the one control, which has one side going to B- was the culprit. It burned, shorted to chassis, and, apparently, overloaded power supply...
Flyback. Dampness dammage.
Horiz. lin. coil. Dampness dammage.
Vert. Hold, horizl. hold controls. Bent shafts.
Maybe 5U4 socket. Acting funny on resistance measurements. May be intermittently shorting to chassis.
A couple of unused black pins.
Electrolytics, caps., resistors. Power cord.
I re painted power transformer after rust removal.
Most of the chassis was dirty enough to prevent rusting.
TV tuner has a light layer of rust, as do tube shields.
Tubes were FILTHY.
That's all I'm doing on this chassis until I start finding parts for it.
I have two tv's to catch up on,, and, other projects.
Tubes were FILTHY.
Great news!!
I have what's left of a 9T240 chassis. I checked, and, resistor on back, and, flyback are exact replacements for the ones in this set.
I still need two controls on back. They are missing on the other chassis.
Vert. out. transformer is also different.
Didn't look up yoke, yet.
But, resistor bank, and, flyback are exactly the same!
Well, today, and, just finnishing 30 min. ago, I stripped two junker RCA chassis's.
One, a rusted out 9T246. Other a 9T240. The later had the correct replacement yoke, flyback, focus control, width coil, and, chassis resistor. I also think the horiz. osc. coil is the same. These I will use in this set.
It also has a good tuner detendt for this set.
I'll then be short on 3 controls. after I get those, I will be able to rebuild the set.
Looks good.
I have some controls for the trashed 9T246 I'm rebuilding. That original chassis sustained alot of rust dammage in bad storage someone had it in a rental storage. Looks like it develodped a leak.
Entire hv section was trashed, along with two of the back controls.
I had that set playing 5 years ago. I had re-capped it, and, rejuved electrolytics. Two weeks later one can failed. I never got around to finnishing it. He wanted it, so, reluctantly, I traded it.
I have it back, and, have alot of work to do.
I had an incomplete chassis with a good hv section, so, I stole parts from it.
That's all for now.
Looks good.
That's all for now.
Just got more great news!
I have an extra chassis from a junked 641 set. That has several needed parts. It has the correct bightness control for my 630, and, correct horiz. hold, and vert. hold, plus, correct height, and, Lin. controls for the 8TR29.
I will need to check all these parts befor installing them, of course, but, at this point, it looks like things are looking up for both this set, and, my 630. Still have problems getting correct power supply resistors for that, and, my721 sets, however. The resistors in 641 are totally different.
Yoke from 9T240 is also an exact replacement for the one in the 8TR29 in case that one is ruinned.
I'd definately say things are looking up on chances of bringing this old gem back to life.
Also, if worse comes to wors, and, transformer is toast, the one from 9T240 appears to be the same, and, that set had low milage. In fact, it had most of the original tubes. If they are good I'll likely put them in this set.
Well, in the months ahead, as I get electrolytics, I suspect this set is going to see a new lease on life. Next step? Repair cabinet, and, stand.
Reimvoed old hv supply tonight.
Alot of corosion all over the place..
Bill Cahill.
Bill Cahill.
Page 1 of 2 • 1, 2
Similar topics» puri family sex kahaniya
» The Trilliant pictures
» Sexiest Pictures of Young Girls
» CTR Tracks Pictures (road images)
» Thread For ALL Wrap Partys Pictures!
Page 1 of 2
