1962 RCA issue
1962 RCA issue
Howdy I'm a newbie to this.
I'm restoring a 1962 Victor 3VF305 console stereo which mostly works well. The phonograph needs a little help though. Among other issues. It has a double stylus, side by side. I've never seen the like. I have tube amp experience but know nothing about servicing these things so any advice would be greatly appreciated, esp. how am I going to "convert" this to play regular LPs?
firemedic- Member
- Number of posts: 17
Registration date: 2011-05-22
Re: 1962 RCA issue
No need to "convert" anything in order to play LP's. You have an RCA 200 series stereo cartridge and assuming it is in working condition, it will easily play modern LP's and it will play them well. I have several players that use that cartridge and they sound great. Just make sure you get yourself a fresh needle for it.
magic brain- Noob
Registration date: 2011-05-25
Re: 1962 RCA issue
I have seen these double stylusses, How do they work? I searched through an old box of needles at a dealer, Roberts Electronics, New London, CT, and found a bunch of them. I found the ones that I needed.
John Maxson- Member
- Number of posts: 43
Registration date: 2011-03-19
Re: 1962 RCA issue
It's quite simple actually. The tabs on the side are indicators, which you slide over to select the stylus you want to use, in my case there is one for LPs and a different one for 78s. When one is positioned properly to play records, the other is tucked safely up and away.
The source of my confusion was that neither stylus was selected, so both were able to play on the record at the same time. It sounded awful. Once I figured it out, it worked great.
firemedic- Member
Similar topics» New issue A4s
» ISSUE OF BONUS SHARES
» 1962 RCA issue
» Game Informer's 200th Issue
» Podocarpus nivalis Issue
» 1962 RCA issue
