GE RADIO MODEL 414
GE RADIO MODEL 414
Post by fr66ed on Sat May 14, 2011 4:03 pm
I have a 1950 GE tube radio model 414. problem i am having is when i turn radio on it plays then all of a sudden i lose station and all I can hear is static. I then retune it and it comes back on. It keeps repeating this. Any suggestions is this is tube or what?
fr66ed
Number of posts: 3
Registration date: 2011-05-14
Re: GE RADIO MODEL 414
Post by Graylox on Sun May 15, 2011 12:50 pm
I won't likely be a tube. Before you run it again, you should look into replacing at least the electrolytic capacitors in the power supply circuit. That would be the 30mfd and 50mfd capacitors.
Link to schematic:
http://www.nostalgiaair.org/PagesByModel/667/M0007667.pdf
Graylox
Number of posts: 18
Registration date: 2010-06-07
Post by Resistance is Futile on Sun May 15, 2011 2:21 pm
I would also suspect that the tuning condenser is either, shorting in the plates, or bad grounding wiper (if it has one) needs to be cleaned and the bearings also if it has those. Check volume control could be intermittent. Hard telling without seeing the problem first hand. Sometimes you can have a failing tube, or small capacitor breaking down. Check all connections for cold solder joints.
Number of posts: 627
Post by sprman on Mon May 16, 2011 7:47 pm
Let it play and gently tap each tube and see if station goes a way..Check all tube pins make sure they are clean and not bent and fit tight in the sockets.. Sprman : )
sprman
Wise Man
Wise Man
Number of posts: 258
Registration date: 2008-03-27
Post by fr66ed on Tue May 17, 2011 10:15 am
Thanks for all the advice will try it and see if I can fix it
fr66ed
Number of posts: 3
Post by denver on Wed May 18, 2011 10:46 am
Like graylok said. Look for a leaky cap.
denver
Wise Man
Wise Man
Number of posts: 381
Registration date: 2010-01-18
